View full version: Body, interior, paint, chrome, and cosmetic items
  1. Removal of screws holding bottom rear chrome on hard top.
  2. Hardtop Chrome
  3. A superb leather restorer preservative
  4. Mercedes replacement panel satin black epoxy?
  5. Bonnet hinges fitting
  6. Taillight assembly process
  7. Just fitted 3point retractable seat belts
  8. Removing deep scratches in steering wheel?
  9. Headrest Adjustment
  10. Jack Plugs
  11. Leather interior restoration
  12. windshield washer fluid hose routing
  13. Not sure at what this is.
  14. Rear Glass for Hard Top (heated)
  15. Trunk Lid Lock Adjustment
  16. Correct Finish to Bosch Horn Screws
  17. rear shock plate and rubber buffer
  18. Any use CalChrome to plate Hubcaps
  19. Replacing trunk floor, advice please
  20. New sill query on adding additional inspection, drainage and anti corrosion hole
  21. My hartop need a new painting. A different color ?
  22. Securing Side Vent Levers on Their Pivots
  23. 70-71 Oil filler cap finish?
  24. Automatic shift gate plastic guide mount.
  25. Visors
  26. Lower Aluminum Trim Clips
  27. Glove Box Screw Help Needed
  28. Where oh where does the trunk wire run
  29. Use of body panel adhesive.
  30. Now for the next question
  31. Slanted headlights
  32. Kuhlmeister AC ON/Off Light Indicator
  33. Replacing front bumper support?
  34. chrome paint
  35. Glove box light removal
  36. Early type mirrors
  37. Hood Buffer Stop question
  38. Are these Mercedes 113 soft top handles?
  39. Is the trunk semi-gloss or matt
  40. Stressful Pagoda Day
  41. Confirm gas tanks are zinc, gal, colour
  42. Dash upholstery
  43. Key issues
  44. Roof compartment stuck shut
  45. Glove box rod
  46. Dashpot Restoration or Replacement
  47. Swage lines
  48. Hard Top Quarter Window Seal
  49. Dash Restoration Questions
  50. Door lock jammed
