View full version: Body, interior, paint, chrome, and cosmetic items
  1. tail light lenses, red
  2. How do I remove the Dash Panel Vents? Problem Solved! Thanks to all!
  3. Soft Top Jammed
  4. Aluminum hood repair
  5. Powder coat rims?
  6. Detailing the 280SL Engine
  7. Short Auto gear lever
  8. Been searching for a good looking and functional steering wheel cover
  9. Trunk & Soft Top Case DB 164 Paint
  10. Rocker panel fixings
  11. Upholstery and Carpet Kit Reviews
  12. Prop shaft centre bearing
  13. Exhaust tip length?
  14. Spring....Door Roller Catch.
  15. Glasurit supplier in Houston?
  16. Bl$#@y window adjustment
  17. Bolts that hold the fuel pump cover
  18. Minor reconditioning of the wood center console
  19. Heater Valve Adjustment
  20. Parts prep for plating
  21. Cracked leather on Driver's side armrest late 230SL
  22. White Walls
  23. bosch horn data plates
  24. Oil Dipstick Color
  25. Window Cranks & Padded Inserts
  26. Speedo
  27. Recommended Chromer
  28. What is this threaded hole for?
  29. 3rd seat in 1968 280sl
  30. 280SL removing door panel
  31. Vin/Paint Code Plate
  32. Comments invited on 230SL Restoration
  33. Fitting door seal 230 SL
  34. Air conditioner instal
  35. Head lamp removal
  36. Use of panel bonding adhesive: my experience
  37. Hardtop Noise --can't figure out
  38. Headlight & Surrounding Crome Bezel UK
  39. Parts list plus listing of all the fasteners.
  40. Nicad or Zinc platers in Houston
  41. Right side mirror...quality of repro?
  42. Vredestein tire issue
  43. Chrome gas cap question
  44. Proper decals for blue ignition coils?
  45. top frame problem_pivot screw
  46. Glove box switch and chrome nut
  47. Old 280 Hub Caps
  48. Original colour or not, that's the question.
  49. Under Hood Rubber
  50. covering around windshield frame
