View full version: Electrical and Instruments
  1. ALL the Luck
  2. correct center cluste (oil pressure wire) removal
  3. Starter won't work
  4. Resolved: Battery cable (+) - what is the "coil" for?
  5. Ignition Control Unit Wire Harness
  6. What most of us fear - a phantom short
  7. Clock repair.
  8. Electrical Connectors
  9. Odometer
  10. Replacing Relays
  11. Replacement cap and rotor
  12. Wiring issues 101
  13. bad alternator?
  14. What is this switch? Is it even OEM?
  15. Fuel Gauge
  16. Wiper connections
  17. Windshield wiper not parking problem
  18. Extra mystery wire for IP starting solenoid
  19. A/C equiped how can you tell ?
  20. Heater and vent controls
  21. Temp Gauge Wire Replacement
  22. Becker TR without DIN Receptacle for Becker Ipod Cable?
  23. Battery clamps...
  24. Difference between distributors
  25. heater effiency
  26. location of Plug Connection Tail Light Leads (46)
  27. BA 9 Instrument Bulbs 4 watts..where to buy
  28. What is this wire hanging off the side of the alternator?
  29. Ignition key
  30. tachometer problem
  31. Overhauling Starter.
  32. Starting Problems:The Key is Key
  33. Unconnected wire...help
  34. Constant Speed Solenoid Always Engaged
  35. Battery polarity question
  36. Becker Europa Wiring
  37. Auxiliary Fuse Box in Engine Bay
  38. Bosch Spark Plug Wires
  39. 55 AMP alternator #
  40. Emission Control Stuff
  41. restored bosch horn
  42. got some WIPER MOTOR blues - -
  43. Replacing bulbs in Center Instrument Cluster
  44. NOTICE: MB part numbers for Instrument and Heater Bulbs
  45. Battery trickle chargers - CTEK products??
  46. access to power antenna
  47. Clock Question
  48. 009 vs 010 Distributor
  49. Is there a Yellow 35 watt fog lamp that fits
  50. Demand for a Yellow Fog Light bulb? Vendor custom run interest?
