View full version: Electrical and Instruments
  1. Oil Pressure Guage stays at Max
  2. Points set quality
  3. Frigiking A/C - How many speeds?
  4. Simple bulb replacement?
  5. wiper relay repair
  6. wipers not working
  7. How hard is it to get a KMH Speedometer?
  8. Under dash electrical plug mount?
  9. IP Pump & Timing
  10. Speedometer - why is my odometer "6" skinny?
  11. Auto Transmission Wiring
  12. Euro lens gasket
  13. headlight switch re-build/clean?
  14. 230SL Time-lag switch - how does it function?
  15. A/C Replacement on 280SL
  16. Electrical Issue
  17. new battery/polarity issue
  18. replacing electrical connectors
  19. highbeam flash sometimes causes washer to activate
  20. Pertronix Ignitor
  21. FM radio drift/static when moving...
  22. Mystery Wires
  23. becker radio europa
  24. Starter inhibitor and reversing lamp switch
  25. Pagoda Clock
  26. Headlight spade connector
  27. Speedometer ( Which one is correct?)
  28. radio type box-what is it?
  29. A/C
  30. What color are wires to glove compartment?
  31. Speedo Flicker
  32. Switch on Venturi
  33. Blaupunkt
  34. Newbie Blaupunkt radio help
  35. Good radio guy Los Angeles area?
  36. Shift Gear lever Light
  37. ballast resistor
  38. Constant Speed Solenoid behaving erratically
  39. wires to power antenna
  40. Which Becker Radio?
  41. both brake lights went out
  42. Spark plug wires
  43. Upgrade to 55 A alternator
  44. Odd speedometer activities
  45. Blaupunkt Radio Speakers
  46. Kick-down Switch (Automatics)
  47. Auto Transmission Pressure Switches
  48. ground wires to instruments
  49. Bracket for radio support?
  50. WIRING QUESTION
