» Electrical and Instruments
View full version:
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
What kind of ignition coil do you have with your Pertronix?
Heated rear window - in the soft top?????
welding and ignition on 280SL
Wiring Connector Location
Restoring Frigiking AC system on '71 280SL
Speedometer & Odometer ratio change
AC Dryer Manufacturer Specs for '71 280SL
Entrance and Glove Box Light Bulb PN Found
Bosch AL 74x Alternator Upgrade question
Need PNs for two grommets
Portable emergency Light
Low fuel warning light - 1964 230SL
280SL Tachometer "C" bracket
Charging light came on and speedo stopped at the same time..
UK RHD Tempory Headlamp deflection for European use
Cleaning Rheostat
Mystery Parts
Mystery switch and dash lights
Relay replacement
Unknown SL 230 Unknown Part
Accessing right hand drive noisy Tachometer drive cable
Turn signal relay '69 280SL
Module under battery tray
Odd light situation
What hole size for column switch indicator rubber cover?
dashboard lights
timing issue
280SL Auto, dies while stopping
Fuse only blows when Car running?
pertronix ignitor and flame thrower
Problems with pagoda.. Please help! :-)
Fuel Gauge - how to test
230 SL battery in the UK
Radio opening
Where to splice into the 4 parking lights?
Bosch Switching Unit
Wires under drivers side dash
headlight function issue,
column switch
Is the all-white battery still available (P/N A003 541 3301)
Need help on where to use rat tail file on turn switch
another sort of short ?
Horns
Becker Europa Question
Turn signal stalk - missing contact plate
Fuel Level Tank Sensor
Becker Mexico Retro
turn signal cancellation '64 230sl
Fuel pump power
removing column switch from 280 SL
