Author Topic: I rolled my pagoda last night...  (Read 152210 times)
Re: I rolled my pagoda last night...
« Reply #75 on: November 07, 2019, 02:52:56 »
There are three different MC for our vintage of cars with hydraulic clutch. They have different inlet and outlet thread sizes which can make matching up what you have a bit of a challenge. If you order like for like you should be OK. I found the unit without a bleeder to be the wrong one and the brake fluid pipes wouldn't fit on both ends, or maybe it was just one end but I ended up having to get the right one to make it all work.
johnk
  • USA, OH, Avon
« Reply #76 on: November 07, 2019, 15:00:45 »
Good points Dan thank you. I will try it this weekend if the fittings don't line up I will consider the 250 version or changing the fittings.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
lreppond
  • USA, CA, San Leandro
« Reply #77 on: November 07, 2019, 15:27:42 »
I’ve thoroughly enjoyed this particular thread.  First of all, I’m in total awe.  This is a big project yet the results are absolutely breath taking and highly informative to boot.  Your color choice is my favorite of all the colors offered by MB back in the day.  It’s showy yet elegant and reserved and shows off the cars bright work perfectly.  I’ll be interested in seeing what interior colors you end up going with.
Thanks so much for sharing your journey with this restoration with all of us.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
johnk
  • USA, OH, Avon
« Reply #78 on: November 08, 2019, 02:31:58 »
Irrepond, You just made my month thank you! i will make sure I post more pics as I go forward.
Below are pics of Fernando Castanfeira's car that is the model for my colors. Fernando has been super helpful in helping me get my colors right, and sent me these pics just yesterday helping to make sure I order the right leather color.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #79 on: November 08, 2019, 03:07:54 »
So my wiper linkage has been my hold up the last two weeks. It was rusted so when I pulled it apart I had to strip and soak the rust off - no problem. I then set up an electroplating system to replate the previously rusted areas. It plated great but for some reason the plastic grommets melted a bit in the process and now the linkage turns harder than I would expect. As soon as my wiper motor gets back from Classic Wiper for a rebuild I will install the linkage and motor and make sure it works before I finish the dash.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #80 on: November 09, 2019, 11:30:10 »
Thats a lovely colour combo - that would be on my list were i starting from scratch
Looks like it's on bigger wheels though that may be the effect of the witewalls
lreppond
« Reply #81 on: November 09, 2019, 14:10:27 »
Oh man, you’re definitely on the right track. I’ve seen a 3.5 convertible in this same paint with parchment interior.  It’s pure Hollywood!   Although it’s very eye catching, there’s also something really restrained too.  It’s the perfect choices IMHO.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
johnk
  • USA, OH, Avon
« Reply #82 on: November 11, 2019, 02:56:30 »
So I learned  new trick from Shvegel recently. I needed to replace my gas line grommets and I could only find 2 online. There is actually about ten of these in the car for different uses. He told me to by a solid rubber line online cut it to length and drill a hole in the center.
Works great and cost less than ten bucks  for the rubber!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
kampala
  • USA, CA, Hermosa Beach
« Reply #83 on: November 11, 2019, 04:59:45 »
The 728 color you have chosen is also the original color of my 280.  Mine is in epoxy primer at the moment after stripping to bare metal waiting to get its 728 back. A Previous owner had the car painted ivory.
As far as I know, there are now at least 6 pagodas within our group with this color. I have seen 5 of them (including mine) first hand:
Drewtee (UK] - seen at our European events
Kemal (UK) - seen at our European events
Donati (California) - drove to Arroyo Grande  (from Los Angles) to meet Donati.
Hauser (Florida) - saw this car at our Virginia Event when Gernold brought it.
Kampala - me - (car lives in California)
Johnk - you - (Ohio)
Any others?
250sl - later - manual
280sl - 1971 - Auto - LSD
mclewis
  • USA, NJ, Saddle River
« Reply #84 on: November 11, 2019, 16:05:37 »
I also have a 728 car, with brown interior and soft top.
Marc Lewis
1968 280SL 728H/728H, 248, 746
2020 C300
2021 E450 All Terrain
johnk
  • USA, OH, Avon
« Reply #85 on: November 11, 2019, 20:19:52 »
Any others?
Not that I am aware of. Houser’s is the one I posted above and he is the one helping me on it. I first saw it at the Virginia event.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #86 on: November 12, 2019, 23:52:40 »
After reading Dr Benz’s helpful email above I priced the clutch master sleeve for a 250 rather than a 280. The only price I could find from our normal supplier was $250, which convinced me to try my old one again first (it had a slight leak).
For the hell of it I jut googled the part and found Rockauto has it for $106 or a close out version by American Remanufacturers for $7.99!
I ordered the 7.99 version feeling lucky. We will see.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
mbzse
« Reply #87 on: November 13, 2019, 00:56:06 »
Quote from: johnk
.../...clutch master sleeve for a 250 rather than a 280.../...
The clutch hydraulic system is different on a 250SL compared to a 280SL.
This is due to the change over to a diaphragm type clutch mechanism on the M130 engine.
The dia for the master and the slave cylinders should be a match to each other, as follows:
230/250 SL clutch master cylinders share the same bore (Ø23.81mm) but come with different part numbers. The slave cylinder is the same for both (Ø25.4mm).
280SL master cylinder is Ø19.05mm bore and slave cylinder Ø23.81mm.
It is not trivial, and as DanC mentions, complicated by use of M12 or M14 fine pitch thread pipe connections.  The SLS website has a useful table; see Section 29.i
« Last Edit: November 13, 2019, 01:06:07 by mbzse »
/Hans S
johnk
  • USA, OH, Avon
« Reply #88 on: November 13, 2019, 03:21:27 »
That's good to learn thank you. My fittings won't work with the 280 Master cylinder so I have to go with the 250. I am afraid now that the slave cylinder I ordered a couple years ago but didn't install yet wont work with the 250 master. I better dig up my old one and see if it works.
Gentlemen you saved me a lot of work and frustration again thank you!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #89 on: November 21, 2019, 04:22:01 »
I decided to start installing the sound and heat barrier while waiting to get my wiper linkage fixed.  Although it seems to me that I should not be covering the transmission tunnel.  The tunnel already has the original fiber matting on it that the new material does not stick to well and I believe the carpeting on the tunnel gets glued on tight. I may pull that off and use it under the kinder seat.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« Reply #90 on: November 21, 2019, 09:40:41 »
How come you decided not to remove the fibre matting over the transmission tunnel?
Peter J
1965 230SL #09474 named Dagny
2025 GLC300 coupe named Rigel
« Reply #91 on: November 21, 2019, 10:25:02 »
"original fibre matting" - I did not know there was one there...
johnk
  • USA, OH, Avon
« Reply #92 on: November 21, 2019, 11:35:40 »
I will post pictures on the matting this weekend when I am back at the barn
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #93 on: November 21, 2019, 11:38:22 »
I guess I could remove it. I wasn’t removing any of the original materials but I guess the new solid material should be better than the original matting on the tunnel.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
cfm65@me.com
  • Cape Town, South Africa
« Reply #94 on: November 21, 2019, 20:33:13 »
Hi John.
My reply post #39 refers.
I am very much in awe of the excellent job you are doing.
I have owned 2 190Sl’s and restored 6, I have also owned 4 Pagodas and a pair of 111’s (a 61 Cabrio and a 63 Coupe) as well as a few modern sedans, station wagons and a few modern SLs.
Keep up the good work.
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
johnk
  • USA, OH, Avon
« Reply #95 on: November 21, 2019, 22:26:27 »
Hi John.
Chris
Cape Town
A thank you Chris! I am in awe of what you have owned and own!  My favorite realistic dream car has always been an E-type since my brother had one in the 60’s. I often wondered if someone offered me a decent price for my 280 when I am done would I seriously consider selling it to get an e-type. I know my son would be heart broken.
If you had to choose which of the two would you select to be your only classic?
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #96 on: November 22, 2019, 00:52:51 »
Hi John.
Chris
Cape Town
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
cfm65@me.com
« Reply #97 on: November 22, 2019, 15:14:25 »
Hi John,
It would be very difficult for me to decide between the E and the Pagoda.
My E Type is in better condition than the Pagoda, however, now that I have the fuel injection sorted and changed auto box with a 5 speed Getrag, SL is much more user friendly than before.
To tell the truth, the 29 Chevy is my daily driver and my favourite.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
johnk
  • USA, OH, Avon
« Reply #98 on: November 30, 2019, 23:37:31 »
Below is a picture of the original matting on the transmission tunnel. It is pretty thick and completely so I Am going to leave it in place and focus is putting the new material behind the seats to help silence the rear axle and road noise.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #99 on: December 12, 2019, 03:59:56 »
So I have done all I can under the dash and it was time to take it off the rotisserie and start the drive train yea!  Removing the rotisserie was kind old like taking off your ski boots after a great day skiing -ahhhhh!
This weekend I will be installing the rear end - any tips on the compensating spring are greatly appreciated. I had the privilege of having Joe Alexander rebuild my differential and the transmission.
The really nice trolley supporting the unit on wheels and keeping the axles
Horizontal is courtesy is Shvegel who luckily also lives relatively close by.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
