Author Topic: 230SL Gauges  (Read 4970 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
230SL Gauges
« on: November 12, 2013, 00:00:21 »
Restoration continues on my 230SL. David Lathem, Brad, Jeff, and the rest of the Bud's Benz team are doing an outstanding job!
I brought the speedometer, tachometer, and center cluster home for a clean-up - thought I'd replace one of the bezels, clean the glass, gauge faces, etc..  I noticed that the speedo bezel had been pried off some time in the past obviously meaning it's been worked on, perhaps to repair the trip meter (which still doesn't work).
At this point I'm not so sure I want to (re) attempt to repair the trip meter or whatever else the PO may have 'fixed' inside the speedometer. I'm considering sending all three (speedo, tach, cluster) to Palo Alto Speedometer for restoration.  I first want to ensure these are original VDO gauges for an early 230. Is it possible to determine these are correct for an early 230 based on p/n on the face of each gauge? Here's the numbers:
Tachometer - 000 542 3716
Speedometer - 003 542 78 06
thanks for any advice, Charles
merrill
Re: 230SL Gauges
« Reply #1 on: November 12, 2013, 00:30:06 »
Charles,
hi,
not sure about the pn's.  you could e mail the classic center to verify.
PA speedo has rebuilt all of my gauges.
they came back nice and clean, new chrome etc.
but after a while, sometimes,  the tach and speedo would not work unless I gave them a gentle tap.
when I asked them about a repair, they wanted me to send them in to get a quote and did not offer to repair under warranty.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
ctaylor738
  • USA, VA, Falls Church
Re: 230SL Gauges
« Reply #2 on: November 12, 2013, 01:20:25 »
Those are good numbers for the tach and speedo according to the EPC.
If your instruments work well, not sure what you would gain by sending them out.  Pretty simple to pry the trim off and clean the glass.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Re: 230SL Gauges
« Reply #3 on: November 12, 2013, 17:14:04 »
thanks for the help merrill and ctaylor, good to know these are correct for my 230. What is the "EPC"?
mmizesko
  • USA, OH, New Albany
Re: 230SL Gauges
« Reply #4 on: November 12, 2013, 18:04:19 »
I believe EPC means Electronic Parts Catalog, from Mercedes Benz, online.
Mike
1970 280SL 291H Dark Olive
ctaylor738
Re: 230SL Gauges
« Reply #5 on: November 13, 2013, 15:00:49 »
Yes, since you are in the US, highly recommend you sign up, it's free.
Go to www.startekinfo.com.
Chuck Taylor
1963 230SL #00133
Falls Church VA
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Re: 230SL Gauges
« Reply #6 on: November 13, 2013, 18:54:43 »
will do,,thanks ctaylor
