Author Topic: Original Kangol seatbelt mounting points?  (Read 3601 times)
Alan Smithee
  • USA, CA, Los Angeles
« on: July 15, 2025, 23:46:57 »
Did searches here and many other places, but could not find any photos...
Can I trouble someone with a later 280SL having original carpet and factory Kangol seatbelts to post photos of the outside mounting points, both top and especially bottom?
Thank you in advance!
Re: Original Kangol seatbelt mounting points?
« Reply #1 on: July 16, 2025, 00:42:52 »
If I recall correctly, all Pagodas have had the same 3-point belt mounting locations since some date in 1966.  My Italian delivery 230SL with an Oct 5, 1966 build date has the mounting holes, but never any seat belts!
But, my point is that you don't need to depend on the specific references you mentioned.
Alan Smithee
« Reply #2 on: July 16, 2025, 19:35:14 »
^  As you pointed out, early cars did not necessarily come with seatbelts from the factory.  I am trying to determine factory correct mounting for belts on a US car, which I believe became law in 1967-1968...hence the request for images from a later car.
I see others have sought this in the past, but no photos in response.  There are dozens of interior shots of dozens of 'original' cars out there...lots of images of Kangol buckles, but annoyingly nobody captures the belt mounting points.
gorgoo
  • France, Île-de-France, Epinay sur Orge
« Reply #3 on: July 16, 2025, 21:49:04 »
You have to look behind the carpet, it's at the bottom corner of the vertical wall behind the seats. If your car had never been equipped in period, you have to punch a hole in the carpet to pass the seatbelt screw (don't drill!)
Sorry, pictures do not pass!
Didier.
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #4 on: July 17, 2025, 00:50:15 »
There are some pictures here
https://www.sl113.org/forums/index.php?topic=13724.0
Attached is a picture from my 68 280sl.  The bottom is mounted in the side instead of the normal spot on the floor
Lori
1968 280SL (US)
Alan Smithee
« Reply #5 on: July 17, 2025, 04:48:14 »
Thanks, but to clarify…looking for photos of the outer seatbelt mounting points of an original car with carpet and seatbelts in place as delivered.
Lori
  • 1968 280SL (US)
« Reply #6 on: July 17, 2025, 10:58:01 »
Not sure what you mean by outer?  There are 3 mount points -
#1 on the tunnel, #2 over the shoulder on the padded corner cover, #3 on the floor behind the seat in front of the parcel shelf.  Brad's pictures in the thread I linked, show all three.
Lori
1968 280SL (US)
« Reply #7 on: July 17, 2025, 13:39:24 »
Taken from the posts on this forum. You may try Search function, key in "seat belts".
I also attach factory sketch.
Alan Smithee
« Reply #8 on: July 17, 2025, 17:48:08 »
Yes, well aware.  Outer being #2 and #3.  Inner being #1 on the tunnel.
You are explaining exactly why I am looking for pictures of an original car with untouched original carpet and original factory-installed belts:  From what I have gathered, factory mounting for #3 is NOT on the floor, but instead on the vertical crossmember supporting the parcel shelf as shown by Pawel66 above.  Beyond confirmation of that, I would like to see how it was finished from the factory in order to replicate it.
Alan Smithee
« Reply #9 on: July 17, 2025, 17:51:21 »
Appreciated, but again looking for photos of a late original car.
« Reply #10 on: July 17, 2025, 20:03:48 »
There were holes in the carpet and bolts screwed in with distance washer. No caps, nothing special.
Maybe there are pictures on motoring investments old site, look for the Holy Grail.
« Last Edit: July 18, 2025, 19:18:25 by Pawel66 »
Alan Smithee
« Reply #11 on: July 17, 2025, 21:17:17 »
Thanks.  Yeah, I went through almost every car on Brian's sites both new and old before posting here, and all photos of the rear areas are cropped just above the mounting point.
« Reply #12 on: July 18, 2025, 01:03:41 »
Can't you feel the holes beneath the carpet?  I know you can feel the shoulder mount under the upholstery.
Alan Smithee
« Reply #13 on: July 18, 2025, 02:20:33 »
Assuming mounting holes are in the body, I would like to see how it looked from the factory before cutting into brand new carpet.
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #14 on: July 18, 2025, 12:45:04 »
So I take it that you replaced the carpet, now that it is new, and you did not see any holes?
Robert Hyatt
Williamsburg, VA.
Alan Smithee
« Reply #15 on: July 18, 2025, 18:29:48 »
I bought the car with non-original carpet and non-original belts incorrectly secured to the parcel shelf screws.
I now have new carpet in, and original Kangol belts that I want to have mounted exactly as the factory did.  For that I am seeking photos of an original car.  I am 90% sure how it should look, but want to be 100%.  I expect correct seatbelt mounting holes are under the carpet since the car is a 1969 US-spec and they were required at that point.
« Reply #16 on: July 18, 2025, 19:21:03 »
Well, you need to feel the hole through the carpet or lift the carpet to locate the hole. Punch the hole in the carpet and fit the belt mounting with a distance/shoulder washer. No mystery there…
« Reply #17 on: July 18, 2025, 20:11:45 »
That's what I was asking.  If you're 90% sure where the holes are beneath the carpet, you should be able to press and find them, then mark them.  No??
Alan Smithee
« Reply #18 on: July 18, 2025, 22:53:56 »
I appreciate all of the input.
Going back to my original post, I am looking for photos of an original car with factory installed belts to see exactly what they looked like new so it can be exactly replicated.  Simple as that.  Spent a lot of money on this interior restoration and not looking to assume, guess, or get it 90% right.
I know there are plenty of original cars out there.  Just need a couple pics from someone who has one.  Thanks.
BHap
  • USA, PA, Pittsburgh
« Reply #19 on: August 11, 2025, 03:29:26 »
Here are a couple of fresh pictures of the outer side connection points for the driver side seat belt on my 70 280SL, which I believe has original carpet.  The upper mount has a plastic cover over the bolt and the lower is exposed. The lower bolt mounting bolt points to the rear in the upright below the rear parcel shelf. The upper fits into an indentation and appears to point at a 45 degree angle to the door and slightly upward. The picture with my fingers is to show the plate sits about 3 fingers in from the door sill upright. Hope the helps.
Bob Happe
Pittsburgh, Pa
Alan Smithee
« Reply #20 on: August 14, 2025, 21:49:21 »
Thank you SO much, Bob!  Extremely helpful and exactly what I was looking for with regards to the lower mounting points.
I believe those plastic covers over the top mounts came from a sedan of same vintage for use of hooking and hanging the belts when not in use.
« Reply #21 on: August 15, 2025, 02:15:24 »
Others - please confirm if the below is correct or not.
See the stitching in Bob's next to last photo?  This shoulder area mount is where the end of the belt is permanently fixed.  The plastic cap just covers the bolt.  The fixture can be rotated up to better guide the belt over one's shoulder, or it rotates down when not in use.  No temporary hooking of the belt.
You should go to Pagodas & Beers, see some other cars in person, and talk with other owners.
« Last Edit: August 15, 2025, 02:24:47 by rwmastel »
neelyrc
  • USA, AL, Birmingham
« Reply #22 on: August 15, 2025, 17:42:20 »
Alan, my 280SL (007749) was delivered to me at the factory in February, 1969, with the US Spec package and still has the original carpet, Kangol belts, etc.  I am separated from my car by a few thousand miles until about Thanksgiving so I can’t provide the specific pictures you are looking for right now. I don’t see that you have mentioned specific details of your car such as date of manufacture.  There may have been some evolution in the exact details furnished in later cars so it would be helpful to know the date of your car’s production.
I looked through the photos I have with me of seat belts and only found three which are attached.  The plastic covers shown in BHap’s post, if original are a later evolution.  I hope this is of some help.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Alan Smithee
« Reply #23 on: August 16, 2025, 18:36:13 »
I think you will find none of the ‘holy grail’ original or 100pt restored Pagodas have these plastic covers.  (That said, I have a set, and plan to use them on mine as it makes for a nice, finished look…original or not.)
Here is an example of what I’m talking about:
https://bringatrailer.com/listing/1971-mercedes-benz-280se-27/
« Reply #24 on: August 16, 2025, 23:33:51 »
I've never seen a seat belt holder like that on the shoulder mounting point of a Pagoda.
