Author Topic: big mistake... [updated: no 😇]  (Read 23335 times)
Re: big mistake... [updated: no 😇]
« Reply #100 on: July 21, 2025, 05:03:57 »
It should have a hole for the spring. You may have it turned around so that the hole is on the back side.
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« Reply #101 on: July 21, 2025, 07:29:09 »
Was it a new thrust/throwout bearing? if not it really is the time to change it which it all out. A new bearing will have the correct hole, as Dan says.
It’s a new one…
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
Figoulu
« Reply #102 on: July 21, 2025, 07:36:24 »
My bearing is new, oem from Benz and identical to the old one. I will double check to see if the old one has holes that I missed but I doubt. If no holes, I will leave it like this…
When I fixed everything I tilted the whole assembly several times and grease all the moving parts… everything seemed to be ok and move smoothly… if apparently those retainers were missing when refurbishing the gear box, having it now is already a good move. Considering the pictures sent by Charles230sl it seems working properly, please Charles correct me if I’m wrong…
I can’t hide that I was happy to put the engine back in the bay yesterday for the 3rd time, (which is fun but a bit repetitive 😁). I fully agree that if something is wrong it has to be addressed, but I have the feeling that it could fly as is…
« Last Edit: July 21, 2025, 07:40:47 by Figoulu »
1965 230 SL
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #103 on: July 21, 2025, 08:05:53 »
Done 😁
As stated by Dan this is clearly wrong. The spring will fall of sooner or later and rear part will start spinning - loose contact with throw out fork.
See attached pictures for correct assembly
1964 230SL
Figoulu
« Reply #104 on: July 21, 2025, 09:03:27 »
Here is my old bearing… 🙈
I know what to do now 🙈🙈🙈
1965 230 SL
Figoulu
« Reply #105 on: July 21, 2025, 10:15:31 »
Everything is out of the car, gearbox as well and this is my bearing 🙈
I will now drill 2 holes in it 😁
Fun continues 😁
1965 230 SL
Figoulu
« Reply #106 on: July 21, 2025, 10:50:52 »
Finished… and much better
Thanks Dr Benz for your accuracy 😁
« Last Edit: July 21, 2025, 10:58:13 by Figoulu »
1965 230 SL
Figoulu
« Reply #107 on: July 21, 2025, 17:24:48 »
Once again back in the car and I hope this time for good 😁
1965 230 SL
Figoulu
1965 230 SL
AndrewB
  • United Kingdom, Channel Islands, Forest, Guernsey
« Reply #109 on: July 28, 2025, 16:49:52 »
sounds good ! Well done
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« Reply #110 on: July 29, 2025, 06:57:51 »
Well done François, quelle satisfaction d'entendre ce doux ronronnement......!
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
Figoulu
« Reply #111 on: July 29, 2025, 08:35:02 »
Thanks !
Now it's time to put back the radiator and proceed to the tuning...
I have to flush the clutch and check about throttle linkage, ignition timing, and CO ratios
I will fix a lambda sensor in the exaust to measure properly the Air-Fuel-Ratio and ajust the FIP in accordance...
Still 1000kms to do, and then back to oil change, head tightening and that will be it... I hope  ::)
1965 230 SL
Figoulu
« Reply #112 on: August 13, 2025, 07:19:06 »
Changed the rotten sway bar bushings and had some issues to make it without significant amount of force…
I then figured out that it couldn’t work like this because the sway bar was hitting the chassis… see the pic…
« Last Edit: August 13, 2025, 07:33:53 by Figoulu »
1965 230 SL
Figoulu
« Reply #113 on: August 13, 2025, 07:22:12 »
Believe me or not, the sway bar has been set upside down… when I understood it couldn’t be like that I corrected the assembly and it went like a charm…
1965 230 SL
Sead
« Reply #114 on: August 13, 2025, 08:06:16 »
take care to tighten the 4 pcs rubber buffer on swing bar correctly.
two hex head nuts are tightened down until you measure 23 +/-1mm from upper nut to the top end of 200mm long main screw.
1964 230SL
Figoulu
« Reply #115 on: August 13, 2025, 08:16:29 »
Thanks a lot. I was about to fine tune this part with the references I took in place before replacing them see pic...
1965 230 SL
« Reply #116 on: August 13, 2025, 10:01:17 »
You're off 16/100 of a mm  ;D
Figoulu
« Reply #117 on: August 13, 2025, 10:58:23 »
Yep that’s my big concern 😁😁
1965 230 SL
Duncan200
« Reply #118 on: August 13, 2025, 11:11:22 »
Hmmm, that’s not even close to the correct value in the metric system 😂
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Figoulu
« Reply #119 on: August 23, 2025, 07:23:37 »
Still into my fine tuning I was surprised to see my crankshaft seal positionned that way… I mean not flush against the block. Is it normal ??
1965 230 SL
