Author Topic: big mistake... [updated: no 😇]  (Read 17220 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
Re: big mistake... [updated: no 😇]
« Reply #75 on: July 02, 2025, 07:31:16 »
Thanks for your explanations and pics... I do NOT have those retainers...
Questions solved and... I need to get those retainers and put them to link the fork and the bearing...  ::)
« Last Edit: July 02, 2025, 08:18:02 by Figoulu »
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
« Reply #76 on: July 02, 2025, 10:43:51 »
They should be available if I read it right...
Figoulu
« Reply #77 on: July 02, 2025, 14:26:13 »
Interesting...
I had only in mind the loop shaped ones, not the clips.
Do we need both of them because I can't clearly see how the clips goes into the assembly
1965 230 SL
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #78 on: July 03, 2025, 01:07:58 »
Here's a long shot for Joe or the Doctor; Is there a bolt on the left side of the engine that threads all the way into the crankcase?  If so, a bolt that's too long might be interfering.
Figoulu
« Reply #79 on: July 04, 2025, 09:02:31 »
Hi Pawel
I looked for those parts but niemoller or sls can't provide the little circle shaped part
Any lead from your side ?
1965 230 SL
Duncan200
« Reply #80 on: July 04, 2025, 09:41:06 »
The circle part you are looking for is the snap ring that fits in the ball socket that the clutch fork pivots on.
I suspect it’s full of grease and you can’t see the snap ring.
Doug.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Figoulu
« Reply #81 on: July 04, 2025, 09:54:19 »
Doug.
Good remark I'll take a look at that before ordering too fast something already inside the fork...  ::)
1965 230 SL
« Reply #82 on: July 04, 2025, 14:44:24 »
Both are there at Mercedes. Yellow dots mean 72 hrs availability, I guess your place will be no different than mine. Numbers 63 and 62, you have part numbers there. One of the has changed - you have the history. Prices are in PLN, divide by 4,4 and you have them in EURO. The higher amount is with VAT.
Figoulu
« Reply #83 on: July 04, 2025, 20:48:58 »
Thanks 👍
1965 230 SL
Figoulu
« Reply #84 on: July 07, 2025, 14:20:05 »
Everything is fine... My pro has pretended that those parts weren't included when i sent him the whole stuff, but... he agreed to send me the 2 parts (clip + hook X 2) free of charge... nice move !  :D
See my mail box soon and keep you updated !
1965 230 SL
« Reply #85 on: July 07, 2025, 15:19:39 »
The throwout bearing slides back and forth on the sleeve and the sleeve keeps the bearing centered on the pressure plate. On a 230SL the clutch fork "fingers" have spring retainers holding the bearing in place (see pics).
Retainer spring is not installed correctly. Should slide into a hole in the mounting sleeve.
1988 560SEC
Figoulu
« Reply #86 on: July 07, 2025, 15:29:16 »
Any pics / drawing to help ?
1965 230 SL
« Reply #87 on: July 07, 2025, 16:09:04 »
Look at the picture of the sleeve with the retainer clip. The straight end of the clip goes into a hole just behind where it is shown in the picture. You will need to unhook the 90 degree end and then find the hole where you start the clip. Clip should be installed straight end first followed by the 90 degree bend or you will probably have a very difficult time getting it to install.
1988 560SEC
Figoulu
« Reply #88 on: July 07, 2025, 16:43:29 »
I'm preparing then for joyfull moments  ;D
1965 230 SL
clunker
  • USA, NJ, Chatham
« Reply #89 on: July 07, 2025, 20:40:49 »
As Dan says, those clips need to be in the fork and the bearing - there are small holes on each, on each side to receive the clip.
Do the least accessible side clip first, put the bent end of clip in back of fork then rotate bearing to get the straight end in the bearing hole. Then on the other side, rotate bearing into position, put the straight end in first into the bearing hole, then push the bent end back behind the fork and into the hole there.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
Figoulu
« Reply #90 on: July 08, 2025, 06:38:57 »
Very helpful, thanks ! ;)
1965 230 SL
