Author Topic: Heater box and blower foam replacement- Best Alternative  (Read 3486 times)
BLTZKRG
  • USA, CA, Pleasanton
« on: December 12, 2022, 00:21:23 »
I had to strip out virtually the whole of my dashboard to rebuild the heater core in my 1970 280SL
I noticed that whenever you pulled anything apart the foam would disappear into dust...I tried finding suitable foam but could find nothing thin enough, I tried using the thin white packaging material, it was simply useless...Then I discovered something very simple, we have a local store that sells Velcro on a roll, its self adhesive. I simply used the soft side and it works perfectly
Here is one of my heater boxes, its such an easy thing to use
Tyler S
  • USA, CA, Encinitas
Re: Heater box and blower foam replacement- Best Alternative
« Reply #1 on: December 12, 2022, 00:46:51 »
Nice job! As these cars age and more parts go NLA, Improvising is becoming a common theme.
roymil
« Reply #2 on: December 12, 2022, 04:21:47 »
thank you for that tip!   I was just about to start putting my dash and heater back together and this will sure be helpful.
Mark Miller
1968 280SL
Rode in his pagoda's first mile.
« Reply #3 on: December 12, 2022, 15:21:59 »
I will probably get into this job this winter.  I've never been into that area of the car.  What is the purpose of the foam?
« Reply #4 on: December 12, 2022, 16:35:48 »
My good friend Barry and I have done this job twice, once on his car, and once on mine. He found a roll of foam material with an adhesive backing. We were able to use that quite easily. I don't recall the vendor but it was nothing exotic. I will double check with him to see if he remembers.
The foam provides a seal between all the hard plastic pieces of the blower box, heater core cover - which, as has been stated, turns to dust over time.
« Reply #5 on: December 12, 2022, 16:43:39 »
The search function is your friend: I used  - "heater core" foam - as the search term and got one page of hits, so it is easy to read through what others have done for the foam.
Here is the link to a few pictures of what Barry and I did for our cars, plus some from a few others
https://www.sl113.org/forums/index.php?topic=21431.msg188137#msg188137
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #6 on: December 12, 2022, 21:06:52 »
Sorry if O/T, but I'm about to tear out the heater blower motor/core/etc.
I already have the speedo out (and center cluster).  Would it be easier if I leave it out?  Or makes no diff?
« Reply #7 on: December 13, 2022, 23:01:23 »
Here is the information about the foam pad we ordered for doing the seals
McMaster Carr. To make it a bit easier:
Prod no 86225K53
Flame-Retardant Super-Cushioning Foam Sheet, Polyurethane with Adhesive back, 24"X24"X1/4"
« Reply #8 on: December 13, 2022, 23:39:27 »
Another alternative, I used this for my Lancia Fulvia heater box foam gasket replacements. Very high quality material actually, I have used it for several other purposes as well. Only 3 mm thick and also available in half that (1/16 inch):
https://www.amazon.com/gp/product/B081PR51GV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
