W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: BLTZKRG on December 12, 2022, 00:21:23
I had to strip out virtually the whole of my dashboard to rebuild the heater core in my 1970 280SL
I noticed that whenever you pulled anything apart the foam would disappear into dust...I tried finding suitable foam but could find nothing thin enough, I tried using the thin white packaging material, it was simply useless...Then I discovered something very simple, we have a local store that sells Velcro on a roll, its self adhesive. I simply used the soft side and it works perfectly
Here is one of my heater boxes, its such an easy thing to use
Nice job! As these cars age and more parts go NLA, Improvising is becoming a common theme.
thank you for that tip! I was just about to start putting my dash and heater back together and this will sure be helpful.
I will probably get into this job this winter. I've never been into that area of the car. What is the purpose of the foam?
My good friend Barry and I have done this job twice, once on his car, and once on mine. He found a roll of foam material with an adhesive backing. We were able to use that quite easily. I don't recall the vendor but it was nothing exotic. I will double check with him to see if he remembers.
The foam provides a seal between all the hard plastic pieces of the blower box, heater core cover - which, as has been stated, turns to dust over time.
The search function is your friend: I used - "heater core" foam - as the search term and got one page of hits, so it is easy to read through what others have done for the foam.
Here is the link to a few pictures of what Barry and I did for our cars, plus some from a few others
https://www.sl113.org/forums/index.php?topic=21431.msg188137#msg188137
Sorry if O/T, but I'm about to tear out the heater blower motor/core/etc.
I already have the speedo out (and center cluster). Would it be easier if I leave it out? Or makes no diff?
Here is the information about the foam pad we ordered for doing the seals
McMaster Carr. To make it a bit easier:
Prod no 86225K53
Flame-Retardant Super-Cushioning Foam Sheet, Polyurethane with Adhesive back, 24"X24"X1/4"
Another alternative, I used this for my Lancia Fulvia heater box foam gasket replacements. Very high quality material actually, I have used it for several other purposes as well. Only 3 mm thick and also available in half that (1/16 inch):
https://www.amazon.com/gp/product/B081PR51GV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
