Author Topic: Driver side rear hub hot after drive  (Read 10363 times)
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Driver side rear hub hot after drive
« Reply #25 on: June 03, 2022, 14:58:34 »
Yes, I bought the tool from Authentic Classics.  I spent more on tools than parts this time...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #26 on: June 09, 2022, 22:46:10 »
Everything is back together and I took it for two 5 mile test drives.  Everything looks good and no hot hubs.
This was not too bad of a job but not easy either.  I was lucky to have no major problems putting everything back together.  The hardest part was bending the lock ring up on the spanner nut.  I had to mark it, then remove it and partially bend it to get it started.
Thanks to everyone for all the helpful info and the Tech manual.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
Kevkeller
  • USA, HI, Honolulu
« Reply #27 on: June 09, 2022, 22:55:27 »
I really wonder what kind of tool they used to lock the washer. It is a tough washer to lock.
1970 280 SL
« Reply #28 on: June 10, 2022, 02:34:41 »
I bent the locking washer up as much as I could then I used a series of different sized punches to expand the metal into the square slot of the nut. I then finished with using a punch that I ground to fit the recess of the slotted nut factoring in each side of the thickness of the lock plate.
Kevkeller
  • USA, HI, Honolulu
« Reply #29 on: June 10, 2022, 02:55:31 »
I did about the same Dan.
1970 280 SL
