Author Topic: removing fuel injectors question  (Read 8498 times)
dirkbalter
  • USA, CA, Corona
Re: removing fuel injectors question
« Reply #25 on: June 24, 2021, 17:59:09 »
here are the torques for a 280SL.
...WRe
Uhh, I guess I didn't look long enough. I this the "flipp book" BBB? I was also looking for the torque values for the copper nuts, mounting intake and exhaust manifold?
(Sorry for high-jacking the post.)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #26 on: June 25, 2021, 01:59:10 »
The figures I had posted previously were a bit lighter than what is in the manual. But the point being is that the torque for the fuel line nut must be lower than the injector. It shows to be 25Nm (18ft lb). That should give you enough of a torque differential so that the fuel line nut loosens before the injector itself.
WRe
« Reply #27 on: June 25, 2021, 07:07:54 »
Hi Dirk,
I couldn't find any torques values for these copper nuts in some workshop manuals but found a recommendation because of size and type of these nuts saying 25Nm should be alright.
...WRe
dirkbalter
  • USA, CA, Corona
« Reply #28 on: June 25, 2021, 14:41:57 »
Hi Dirk,
...WRe
WRe,
Perfect, thanks
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #29 on: June 25, 2021, 16:08:04 »
I am not entitled to add my 2 cents here due to limited experience, but I did this job several times and it is to me like snagging a spark plug: you feel when the seal resistance starts, then you compress it a bit...
dirkbalter
  • USA, CA, Corona
« Reply #30 on: June 25, 2021, 17:02:01 »
PaweL,
I used to do the same until I screwed up an alum BMW motorcycle cyl head. After that, I try to use torque settings or wrenches as much as possible.
As they say in Germany: "Nach fest kommt ab".    :)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
WRe
« Reply #31 on: June 25, 2021, 17:53:44 »
I used to do it as most of us did it over the years that is to say without a torque wrench and a lot of feeling.
First time I used a torque wrench I allways got frightend because of this loud click where you never knew if it was the screw or the wrench.
The first cylinder head bolt I tear off was with a torque wrench.
...WRe
« Reply #32 on: June 25, 2021, 17:56:50 »
PaweL,
Very true :)! All that is ahead of me!
WRe experience confirms reaching targets with minimum effort makes sense :).
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #33 on: June 26, 2021, 04:28:04 »
    If your injectors are as corroded as they seem to be, its also likely that there is some of the same  scale deposits down inside at the pintle end as well. I would recommend bench checking them all as I did with this test rig I bought and adapted.
It allowed me to visually check the spray pattern and cracking pressure on each one of them.
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« Reply #34 on: July 06, 2021, 10:59:16 »
After cleaning  ( diagnostic one injector dripping at a low pressure) by myself with the mercedessource kit and checking by a specialist , i have now 6 beautiful injector on the bench....
I have a question before refitting them on the engine:
do i need some grease on the threads
injector // head
injector // fuel pipe
I think copper grease would be correct  but i need confirmation  ....!  ;)
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
FGN59
« Reply #35 on: July 06, 2021, 11:10:50 »
Hello Yves,
From one Frenchman to another, where did you gave the injectors tested / cleaned ?
Thank you
yves
« Reply #36 on: July 06, 2021, 11:57:16 »
SLS Eurotrading  (03 88 82 70 52 )  they charged 60 eur for 1 inj . they are quite reactive  : 10 days mailing included !
I am refitting them this afternoon .... and am raring to drive and test  with the new gear levers bushes fitted in the same time  ;)
« Reply #37 on: July 06, 2021, 17:31:59 »
The best is a Nickle based anti-seize. Use a tiny amount on injector threads and then on fuel line fitting.
