Please check out joining the Emergency Contact List for help during your travels!
Well No progress with the ultrasonic bath for 2 hours.... The defective injector remain defective... So i send all the injectors to a injector specialist even if 5 of them make a nice " tchip tchip" when i put them under pressure at 220 PSI without any dripping before .At least i think i should have only one injector to replace Btw i was thinking about refitting them on the engine after refurbishing : what is the torque for the injector and for the pipe nut ?
Hi,here are the torques for a 280SL....WRe
Hi Dirk,I couldn't find any torques values for these copper nuts in some workshop manuals but found a recommendation because of size and type of these nuts saying 25Nm should be alright....WRe
PaweL,I used to do the same until I screwed up an alum BMW motorcycle cyl head. After that, I try to use torque settings or wrenches as much as possible.As they say in Germany: "Nach fest kommt ab".
