Author Topic: ZF 5 speed manual Transmission  (Read 2740 times)
CapTom
« on: April 15, 2021, 20:49:17 »
Hello
Anyone out there know a shop that can access and repair as necessary an old ZF 5 speed?  I have contacted the MB Classic Center in Irvine, they know no one.  Talked to San Mateo Transmission, the shop in Burlingame who I thought serviced them.  They only do automatics.
I am local in San Diego closer the better but of course want someone who knows what they are doing.
Thanks in advance.
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: ZF 5 speed manual Transmission
« Reply #1 on: April 15, 2021, 21:30:57 »
You can try maybe Metric Mechanic?
Harry
  • USA, TN, Knoxville
« Reply #2 on: April 28, 2021, 12:29:55 »
I see on EBay Motors that there are used ZF 5 speeds from everything like trucks to BMWs.  I suppose we're not lucky enough for any of the BMW trannys to fit in one of these cars?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #3 on: April 28, 2021, 17:01:24 »
I did some repairs on my own ZF several years ago and I can tell you that they are nothing like the MB box. All of the bearings are press-fit and all except the input shaft bearing are taper roller bearings similar to what you would find on a wheel bearing set up.  All the syncro rings are steel except the reverse gear which is brass. Getting the end play right on the bearings is a treat on those things.
Harry
« Reply #4 on: April 28, 2021, 18:33:17 »
Thanks Dan.  Figured it would be too good to be true.  Sure would be nice to have the lower RPMs though, huh?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
