Author Topic: Glovebox Spring Sleeves  (Read 19734 times)
Chris Long
  • USA, NJ, Morristown
« on: April 24, 2020, 19:21:12 »
My spring was bent on my glovebox causing a  lack of tension.
In replaced the spring and decided to sleeve it per the technical manual so i never have to worry about it.
https://www.sl113.org/wiki/Interior/Glovebox
Now have extra material so cut a few spares. If anyone needs one please let me know. Postage plus a donation towards flowers  for asking my wife to go to post office is all I ask.
Best
1970 280sl 4-Speed Horizon Blue
calhippie
  • USA, CA, IRVINE
Re: Glovebox Spring Sleeves
« Reply #1 on: April 24, 2020, 19:48:13 »
PM sent.
Geoff
Light Ivory
cfm65@me.com
  • Cape Town, South Africa
« Reply #2 on: May 11, 2020, 13:16:50 »
Great idea, Arct1k
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #3 on: May 11, 2020, 21:03:26 »
This works very well. Additional point may be: if your pipe is/comes out a bit lose on the spring and you worry it may rattle, I think it is ok to glue a bit of foam between the pipe/tube and the side of the box.
cfm65@me.com
« Reply #4 on: May 14, 2020, 16:30:34 »
Hi Guys,
Or cover the tube with a bit of shrink sleeve.
In fact, I covered the spring with shrink sleeving.
Cheers
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #5 on: May 14, 2020, 20:53:07 »
In fact, I covered the spring with shrink sleeving. ..
Chris, I am surprised the spring still works, that is, expands and contracts freely. 🤔
cfm65@me.com
« Reply #6 on: May 16, 2020, 18:51:12 »
Yep Alfred, works fine. The shrink sleeving is not shrunk. The piece I used is just a nice fit, without interfering with the spring action and it does not cover the whole spring. Slightly shorter than the spring.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
Chris Long
« Reply #7 on: May 18, 2020, 02:12:22 »
1 left. Rgds
Chris Long
« Reply #8 on: August 20, 2020, 20:44:18 »
All gone - If folks want more; I'll create a list and when get to five i could make a batch
Paul Cain
  • USA, CA, Newport Beach
Re: Glovebox Spring Sleeves / Feedback
« Reply #9 on: August 24, 2020, 03:47:03 »
I purchased this sleeve from Arct1k.  It works great.  It was easy to install and makes for a very smooth spring action across the entire arc of the door swing.  A great fix and not visible.
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« Reply #10 on: June 15, 2021, 19:19:03 »
Arct1k, a little late but did you ever do another batch of these? Would be useful whilst I have the glovebox out.
1971 280SL auto #571 over parchment
col320ce
« Reply #11 on: June 17, 2021, 03:15:34 »
I used a plastic blood tube. Just cut to length and works perfectly. Can post a tube to anyone in oz if interested
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
aharalam
  • Australia, Victoria, Caulfield North
« Reply #12 on: July 06, 2021, 13:55:02 »
Hi Col - I'd take one if you have a spare length.
Aharalam
1967 250SL (LHD/Auto/Papyrus White/navy MB-Tex)
2004 CLK55 AMG (Black/Black)
Runale
  • Malta, L-Iklin, Iklin
« Reply #13 on: July 06, 2021, 15:42:52 »
I would take a length too.  Rubber tubing and sleeve tends to deteriorate with the opening and closing.  Please let me know where to send the donation for the flowers!!
Alessandro
250SL 1967
Alessandro
1967 250SL G050 G040
1979 W123 200D
2019 DB11 AMR
Chris Long
« Reply #14 on: July 06, 2021, 23:43:11 »
lreppond Just ordered some pipe and has made some. He may be willing to make a set for you guys.
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #15 on: July 16, 2021, 13:54:40 »
Would also be interested. Where to forward $?
Robert Hyatt
Williamsburg, VA.
Chris Long
« Reply #16 on: July 17, 2021, 02:25:18 »
Ok for fun I’ll do another batch.
Rahul
« Reply #17 on: July 17, 2021, 03:19:32 »
I actually just cut a few today when making one for myself.
I erred on the side of caution and cut them approx 44-45mm long.
I have eight spares that I can mail out. PM me and I'll try and figure out postage.
Thx to Arct1k for the inspiration to get off my ar5e and do it!
« Last Edit: July 17, 2021, 03:48:20 by rajiggyfizzle »
Chris Long
« Reply #18 on: July 18, 2021, 17:24:25 »
They should be ok - I followed the wiki whihc said to make them 49mm...
jpressick
« Reply #19 on: August 18, 2021, 12:52:45 »
Would love to have the sleeve for my 250 SL and would gladly donate funds for flowers and postage. Are the sleeves still available?
« Reply #20 on: August 18, 2021, 14:14:58 »
I took a piece of thin wall brass pipe and cut to length. I bought the pipe in one of the DIY stores.
Jordan
  • Canada, ON, Jordan
« Reply #21 on: August 18, 2021, 14:49:56 »
Could not a piece of 5/16" (7.9mm) brake line be used as the sleeve?
Marcus
66 230SL  Euro 4 speed
lgarret
  • USA, ID, Caldwell
« Reply #22 on: August 31, 2021, 15:50:55 »
arct1k, ill take one if you made more and thanks.!!
Lance
65 230sl automatic us
568 signal red
Chris Long
« Reply #23 on: September 08, 2021, 18:11:40 »
Pre-Order List so I buy enough pipe:
- Igarret
- jpressick
- awolff280sl
- zoegrlh
Confirming you all want one still - Anyone else?
jeblack123
  • USA, GA, Albany
« Reply #24 on: September 08, 2021, 21:07:09 »
Good afternoon,
I would like a set as well if you are able to accommodate.
James (Eddie) Black
