Author Topic: Valve Cover Sticker  (Read 17065 times)
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Valve Cover Sticker
« Reply #50 on: February 10, 2020, 13:55:47 »
Here is my valve cover decal using the paper above.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #51 on: February 10, 2020, 14:22:59 »
You can certainly use sticker paper (best is mat, printing is worse usually on gloss) - but then I would definitely use clear foil on top or varnish or both as paper would catch stains easily. This is what I did with the Varta sticker you saw - this was paper + clear foil.
alpina
  • Spain, Asturias, Villaviciosa
« Reply #52 on: February 10, 2020, 14:35:31 »
Any print shop should be able print on vinyl to create you the decals. Send them the PDF file. I have printed on gloss sticker paper, and these have held out very well.
I also had them printed at a local print shop on vinyl. i was charged less then a Euro.
for those who have not noticed, i have re uploaded the files on the earlier post with a minor tweak.
WRe
« Reply #53 on: February 10, 2020, 18:03:52 »
there is another valve cover sticker dealing with the spark plugs.
...WRe
« Last Edit: February 10, 2020, 18:52:30 by WRe »
mrfatboy
    • Mrfatboy
« Reply #54 on: February 10, 2020, 18:05:34 »
...WRe
Do tell🤣
Signal Red
4 Speed
alpina
« Reply #55 on: February 10, 2020, 20:04:45 »
i reproduced this one, it is included in the engineerig tag / decal set.
https://www.sl113.org/wiki/uploads/Restricted/EngineeringTags.pdf
