Author Topic: Matti´s 280SL  (Read 55363 times)
mercakungen
Re: Matti´s 280SL
« Reply #50 on: November 19, 2018, 06:10:48 »
Fun part of the project has began.
SwedenBens
  • Sweden, Västra Götaland, Alingsås
Re: Matti´s 280SL
« Reply #51 on: November 19, 2018, 06:33:32 »
How is the reforestation progress?
mercakungen
Re: Matti´s 280SL
« Reply #52 on: December 17, 2018, 09:50:06 »
some progress
mercakungen
Re: Matti´s 280SL
« Reply #53 on: December 17, 2018, 10:08:43 »
Got every cavities treated against rust. What a messy job. After cleaning was time to add some sound insulator. I used 4 mm thick bitumen. I did not blacken certain areas on purpose. I like them this way. It is easy fix them later if I change my mind.
neelyrc
  • USA, AL, Birmingham
Re: Matti´s 280SL
« Reply #54 on: December 17, 2018, 12:28:03 »
Looking beautiful Matti!👍
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
mikeswplt
  • USA, TX, Lago Vista
Re: Matti´s 280SL
« Reply #55 on: December 17, 2018, 14:57:30 »
Beautiful work you’re doing. Where do you get the bitumen sound insulation?
‘68 250SL    under restoration
‘11 RR Sport
‘22 Silverado 2500HD
‘95 F355 GTB
mercakungen
Re: Matti´s 280SL
« Reply #56 on: December 18, 2018, 05:34:03 »
Thank you guys,
I bought the bitumen direct from a Finnish sound insulation manufacturer. I´m not sure if this really is their own product. It is available in many stores here.
Hope the link works.
http://meluton.fi/en/
star63
  • Finland, Etela-Suomen Laani, Vantaa
Re: Matti´s 280SL
« Reply #57 on: December 19, 2018, 13:42:35 »
Looks great!  :)
Petri
'67 250 SL (early)
'66 230 SL (long project)
Finland
mercakungen
Re: Matti´s 280SL
« Reply #58 on: January 24, 2019, 09:40:05 »
Kiitos Petri. Not much progress. What a job to get the wiring harness through the big rubber grommet...
swood1
  • United Kingdom, England, Worcester
Re: Matti´s 280SL
« Reply #59 on: January 27, 2019, 00:03:29 »
Looks really nice, did you replace the harness?  It looks brand new, I am in two minds myself about replacing mine.
Also, I like your paint finish it looks metallic.
Steve
250 SL (early), in bits. Triumph TR4a
johnk
  • USA, OH, Avon
Re: Matti´s 280SL
« Reply #60 on: January 27, 2019, 02:06:09 »
Damn you do nice work Matti!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
mercakungen
Re: Matti´s 280SL
« Reply #61 on: January 28, 2019, 05:33:10 »
Thank you Steve and John. The wiring harness is original. Just clean it and replaced old tapes. For under dash section I used "hockey stick tape". Trunk light wires were broken so I replaced them.
BR,
Matti
doitwright
  • USA, IL, Willowbrook
Re: Matti´s 280SL
« Reply #62 on: January 30, 2019, 05:32:35 »
I discovered a method for installing the main wiring harness through the firewall grommet. It involves using a US 1-1/2” PVC sink drain “tailpiece”. The ID of the PVC is just enough to fit the wire harness through the grommet without removing connectors from the wires. The PVC is used to stretch open the rubber firewall grommet hole. While not necessary, I left the old grommet in place on the harness until I got the harness through the new grommet to the point of the original. Once the new grommet is in the proper place, I cut off the old grommet and the PVC pipe. The Tailpiece has a thinner wall than standard 1-1/2” PVC schedule 40 pipe. The tailpiece also needs to have one end slotted in order to create a tapered end like the point of a large pencil. Some force and Vaseline is needed to push it through the grommet but the grommet did stretch without tearing.
Frank Koronkiewicz
Willowbrook, Illinois
swood1
Re: Matti´s 280SL
« Reply #63 on: January 30, 2019, 07:48:16 »
Can I ask what do all the dabs of paint represent on the suspension and rear drive assembly?
I noticed you are using different colours on different parts.
Steve
mercakungen
Re: Matti´s 280SL
« Reply #64 on: January 30, 2019, 08:21:09 »
Frank: I spent several hours dismantling every connector...
Steve: Those dabs are "the dotology". Lots of discussion of those on this forum. I just copy what I found when I dismantled my car.
BR,
Matti
RobSirg
Re: Matti´s 280SL
« Reply #65 on: February 03, 2019, 02:04:55 »
Hi Matti,
Can I ask where you sourced your firewall padding from?
I've had a few failed attempts from our usual suppliers, despite taking extra care, heating it up first, etc. Seems to be limited options for RHD firewall padding.
Thanks in advance - beautiful work BTW.
Cheers
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
Re: Matti´s 280SL
« Reply #66 on: February 03, 2019, 02:35:27 »
Matti,
Beautiful job on the wiper motor.  That’s a tough one to get right.
Re: Matti´s 280SL
« Reply #67 on: February 03, 2019, 03:13:27 »
Rob,
I think the firewall pad used is the one being sold by Authentic Classics in USA
RobSirg
Re: Matti´s 280SL
« Reply #68 on: February 03, 2019, 23:07:53 »
Thanks Garry - my guess would be Vintage Euro Parts - let's see what Matti confirms.
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mercakungen
Re: Matti´s 280SL
« Reply #69 on: February 04, 2019, 06:21:34 »
Thanks guys. The firewall pad came from Authentic Classics. I painted it after installation to get more original look. Without paint it looked brown and had fuzzy surface. The material itself is close to original.
BR,
Matti
RobSirg
Re: Matti´s 280SL
« Reply #70 on: February 04, 2019, 11:54:13 »
Thanks Matti,
That explains it  - yes, it does look better after your surface treatment.
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
Re: Matti´s 280SL
« Reply #71 on: February 04, 2019, 14:25:33 »
Matti,
Do you have these markings in your “dotology”?  Our cars are the same specification so they should match yours.
swood1
Re: Matti´s 280SL
« Reply #72 on: February 04, 2019, 20:59:52 »
Isn't marking the shock absorbers a little over the top?
Steve
mbzse
Re: Matti´s 280SL
« Reply #73 on: February 05, 2019, 18:18:30 »
Re: Shvegels picture
The W113 Pagoda had four green paint bars on each of the Bilstein shock absorbers (see for instance Book of Tables)
« Last Edit: February 05, 2019, 22:36:55 by mbzse »
/Hans S
mercakungen
Re: Matti´s 280SL
« Reply #74 on: February 07, 2019, 07:37:45 »
Four bars on original shock absorbers. I´m not sure if I´ll paint the bars or keep the Bilstein stickers.
