Author Topic: 280sl restoration  (Read 65281 times)
Joel
Re: 280sl restoration
« Reply #100 on: December 17, 2016, 14:45:30 »
époxy exterior
Joel
« Reply #101 on: December 17, 2016, 14:49:34 »
cleanup Inside and also epoxy
Joel
« Reply #102 on: December 17, 2016, 14:55:00 »
and the front sheet metal work is done
new video:
https://www.youtube.com/watch?v=WllTbe0d1OA
Kevkeller
  • USA, HI, Honolulu
« Reply #103 on: December 26, 2016, 19:47:33 »
Phenomenal restoration!  You are a master craftsman. I'd hate to have to pony up the money to pay for that job!
There's going to be very little left of the original when you're finished. Thanks fir sharing!
Kevin
1970 280 SL
Joel
« Reply #104 on: December 28, 2016, 21:42:15 »
Thank you Kevin,
I'm very happy that the 113 parts are available. Imagine that I would have to imitate every part that is rusted out  :o
Joel
« Reply #105 on: December 31, 2016, 16:37:06 »
left rear
Joel
« Reply #106 on: December 31, 2016, 16:47:26 »
Inner wheel arch is not available, so recovered the old one
guyke
  • Belgium, Flanders, Hasselt
« Reply #107 on: January 01, 2017, 10:47:50 »
man daar bleef toch niks goed over van dezen auto , waar heeft deze gestoken om zo verroest  te zijn , ik durf de mijne al nie meer laten zandstralen  ::) :-[ :-[ :-X
« Reply #108 on: January 01, 2017, 13:16:38 »
Translation: Man, there's nothing left of this car. Where has that been, to be so rusted? I don't dare have mine sandblasted anymore!
Joel
« Reply #109 on: January 01, 2017, 15:31:15 »
 :D
It was a complete and driving car when I saw it for the first time a year ago.
Remember, unless you have an original and unrestored car you never know 100% what you buy. I've worked on a lot of old cars (from ferrari, jaguars to citroen and opel) and rarely saw well restored car. Certainly the "restorations" from before the classic car boom. A lot of the "restaurations" wear just to flip the car to make money or a cheap and fast fix to get them back on the road.
A beautiful filler and paintjob can hide many surprises.
Joel
« Reply #110 on: January 01, 2017, 15:33:43 »
new Outer wheelarch
Joel
« Reply #111 on: January 01, 2017, 15:36:37 »
Making the missing piece.
Joel
« Reply #112 on: January 01, 2017, 15:41:22 »
Joel
« Reply #113 on: January 01, 2017, 15:43:44 »
cleaned up the wing
Joel
« Reply #114 on: January 01, 2017, 16:28:09 »
epoxy
m300cab
  • USA, Pennington New Jersey
« Reply #115 on: January 07, 2017, 20:00:42 »
Nice work!
Michael Parlato
guyke
« Reply #116 on: January 07, 2017, 20:36:50 »
is there a way to look in to the cavitys ( spots not to seen by eye ) in the pagoda for rust , my car look rock solid but after these pics from the car jou are restauring  ::) ::) ::)
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #117 on: January 07, 2017, 22:51:56 »
Gurke,
I think there are some openings you can get into, then use a borescope (best type is a Olympus with a fiberoptic flexable tip that allows you to rotate the tip 360 degree during inspection, controls to move 360 degree are on the hand heald section of the scope}. There may be places you can rent one (see link below). The first one I ever used I rented from Olympus then later I purchased one (now sold since I'm no longer in business). I used it for steam path inspection on turbogenerators and hot gas path inspection on gas turbines. They are great scopes.
Dieter
Link here ----> http://www.olympus-ims.com/en/fiberscope/
Joel,
Great stuff continue the excellent work.
Dieter
« Last Edit: January 07, 2017, 22:57:56 by Rolf-Dieter »
Joel
« Reply #118 on: January 08, 2017, 11:17:22 »
Thank all.
I use also a Cheap inspection camera (see link: http://alphametal.be/nl/component/mijoshop/product/52736-silverline-inspectiecamera) not quality to use every day but every now and then. 131euro is not the end of the world and it can come in hand on other projects like engines.
Joel
« Reply #119 on: January 08, 2017, 11:21:03 »
door and boot lid mounted back to adjust the wing back on the good spot.
Joel
« Reply #120 on: January 08, 2017, 11:23:57 »
done
Joel
« Reply #121 on: January 08, 2017, 11:28:25 »
again all panels back on to make sure that it is ok.
Howard Long
  • USA, GA, Woodstock, Georgia
« Reply #122 on: January 08, 2017, 18:03:31 »
There certainly are inspection holes into almost every cavity.  I have my 280SL on a rotisserie and there are 2 mm access holes to get into nearly every cavity.  Many of the access holes have rubber hole plugs that can be removed and replaced. I suspect that all access holes had rubber plugs at one time but many of mine had been removed or lost.   Some holes in a completed car would be covered with upholstery or carpet that would need to be removed or at least peeled back to get to the access hole.  I  have a cheap Centech camera with a three foot probe to look in to each cavity. Resolution could be better but you can get an idea of where the problems are.  Some cavities have little or no rust but some areas need attention.
As I have replaced the frame rails and floors on each side I have inspected the inside of the A & B pillars and other cavities.  Then I have treated each cavity before I closed the bottom opening.  Then I use the access holes to spray the inside of the areas that I just welded closed. For rust treatment in those cavities, I have been using a rust encapsulating product from Eastwood.  "Eastwood Internal Frame Coating, Item #12515Z"  This is in a aerosol can with a special 360 degree spray nozzle on 24 inch plastic hose to get into the cavities.  I am certain that there are other similar products to do the same job.
I am currently working in the passenger side front wheel well to replace the reinforcing strut and deal with other rust areas.  I am inspecting and treating the cavities in that area as I go.  I realize I cannot get to all of the rust but I am trying to do what I can do.
I admire the great work that Joel is doing on his project car.  I wish I had the time and skills to do my car to that level.
Howard
71 280SL 4-speed
Rolf-Dieter ✝︎
« Reply #123 on: January 08, 2017, 21:38:20 »
Thanks Howard for providing this Eastwood spray coating, looks like a great product. I will order some and carry out a cavity inspection on my baby. I looked it up and added the link below for others.
Dieter
coating link ---> http://www.eastwood.com/internal-frame-coating-w-spray-nozzle-qt.html
Howard Long
« Reply #124 on: January 08, 2017, 21:49:34 »
Deiter,
When you use that Eastwood spray be prepared for it to leak out somewhere,  Put down papers to catch the excess.  It is really good at what it does and it bonds to the floor of the garage real good or to anything else that it drips on.  You might ask how I know.
I have been using the Green version but I see that they now make it in black.  I think the green has advantages done the road when you look into the cavity again.  New rust is likely more like black than the green.
Howard
