Author Topic: Rear Axle Modification  (Read 17362 times)
« on: September 01, 2004, 21:21:27 »
Someone recently suggested...
"Drive the car a bit first to see if you want a taller gear.  The stock axle ratio gives 4600rpm at 80mph..  This can be changed to 3700 at 80 with a different axle."
Obviously this would make the car slower off the line but a lot more tolerable at higher speeds.
Can anyone elaborate on the cost / difficulty to achieve this and their satisfaction with a similar modification?
1964 356C
Re: Rear Axle Modification
« Reply #1 on: September 01, 2004, 21:50:23 »
I put a 3.27 in my car. Makes a whole new automobile out of it: I cruise at about 3000 RPM on the freeway at 63MPH. I do not feel that the car is slower off the line, but it should be. If I really want to beat that Audi or Porsche, I start in first gear. My cost was $250 for the axle plus new bushings, maybe another 50 bucks. It's quite a bit of work and you have to be careful removing the compensator spring. But if I can do it, so can you. The attached picture shows the new axle ready to install
Download Attachment: RearAxle.JPG
82.66 KB
« Reply #2 on: September 02, 2004, 11:26:27 »
This car does not have a spedometer. But it has the original speedometer and it now reads 25% slow; i.e. 40MPH is really 50. On the funny side: 50MPH is 62.5MPH which is exactly 100Km/hr. So I made stickers to go on the glass in a few places, like at 30 (is 38) 50 and 60 (is 75). That takes care of our usual posted speed limits. Because of my extensive education I am also able - sometimes - to multiply the indicated speed by 1.25. It is especially easy when the speedometer indicates 100MPH
« Reply #3 on: September 02, 2004, 15:36:34 »
I put a 3.69 (was 4.08) in mine. The car was slower off the line, but now that my engine has been rebuilt, it's quite peppy again. Although the RPM's went down by around 10%, the difference is less noticeable than I had hoped for. Still an improvement I would recommend.
Malc
« Reply #4 on: September 03, 2004, 01:29:00 »
Being cheap :)  Did you get the diff out of another Mercedes, scrap car or what???
Or are these diffs unique to the 230/280 range?
Malc
Oh BTW can you get limited slip differentials for a 230??
« Last Edit: September 03, 2004, 01:30:58 by Malc »
« Reply #5 on: September 03, 2004, 07:12:41 »
I've got the car completely apart right now, gauges out and everything. Does anyone know if the speedometer could be recalibrated (by a professional)to synchronize with a modified rear end?
If it can be done, now is the time! Also, it seems like half of the professional guage shops, repairers and restorers are in Van Nuys, CA. Anybody have a particular shop reccommendation?
« Reply #6 on: September 03, 2004, 08:00:50 »
North Hollywood Speedometer is terrific. I sent a speedometer there on a Monday and got it back as-new on a Thursday.
www.nhspeedometer.com
« Reply #7 on: September 03, 2004, 10:06:42 »
The differential I had put in came from a sedan car. And yes it was cheap: as I recall something like $400 including labor to put it in, and that took an entire day.
« Reply #8 on: September 03, 2004, 10:22:19 »
The tallest you will find in swing axle  will be the 3:27.
 Keep a look out for 108 chassis , 280SE 4.5 only ..
 The 280SE , 6 banger does not use the 3:27... they figured the v8,3:27 match would be the best for a large sedan with the added power, but you can do the 113  cuz of the lighter weight , but it is more recommended for stick vs auto...
 Opionions vary... I've had  both ... if you do around town/back road driving , stay stock... but if you are a cruiser , the 3:27 makes it a new car on the highway...
 I think it is an American thing....
 If one does the math , the cruise of the 3:27 comes close to the RPM/MPH specs of the ZF  5 speed O.D in top gear.........
« Reply #9 on: September 04, 2005, 19:55:52 »
In another topic the effects of high gas prices (and more philosophical and social aspects) are being discussed.
I was wondering whether any of you know how the gear ratio affects the gasoline consumption (in mpg or ltr/100 km, I don't care which unit we use). In theory I'd say that a lower ratio (lower rpm at same speed) should improve gas mileage. But is that true in reality?
Perhaps Theengineer could tell us whether his gas mileage got better after the exchange.  Ed, have you driven your car often enough to report your's? What gear ratio did you finally settle on?
« Reply #10 on: September 04, 2005, 22:35:22 »
Gas mileage / rear end question:
Probably depends on how and where you drive your car; city or highway. I did not change the rear end in my car and have not found driving at 70 - 75 mph to be annoying at all (as I thought it might be from some of what I had read).
1973 911S
2004 A4 3.0
2006 GS430
« Reply #11 on: September 04, 2005, 23:02:14 »
I did not notice a drop in fuel consumption after going from 4.08 to 3.69.
  • USA, VA, Alexandria
« Reply #12 on: September 05, 2005, 20:42:09 »
I went from a 4.08 to a 3.27 rear-end.  Too many overall changes to isolate any gas mileage benefit from the 3.27.  I can say that while cruising with the top down at 60 mph, I have to listen hard for the sound of the engine.  Driving around town is not bad, and if you need the extra push, you can use the shifter (automatic).
Joe Alexander, Pete Lesler and I did some back of the envelope calculations at the Ohio tech session and determined that the 3.27 had a slight rpm advantage over the 5 speed ZF.  That was after several libations, so maybe the calculations were off. :D
« Last Edit: September 05, 2005, 20:48:11 by Tom »
« Reply #13 on: September 05, 2005, 23:23:41 »
<<determined that the 3.27 had a slight rpm advantage over the 5 speed ZF.>>
 The 3:27 would have quite the advantage on RPM.
  A ZF520 in 5th gear with a diff ratio of 4:08 would equate to the same RPM as a 4 speed in top gear with a 3:46 ratio differental.
« Reply #14 on: September 06, 2005, 03:16:48 »
I must have a different back end to you lot already
I figure 50rpm per mph in top gear (280, Auto). It sits at
4000rpm/80mph or
3500rpm/70mph or
3000rpm/60mph
very happily.
Only having ever driven the one car, I have no basis for comparison
« Reply #15 on: September 06, 2005, 08:33:15 »
Mike Halleck ("Norton") is supposed to be putting a Mustang T5 transmission in his 113.  It will be interesting to see if this has the intended result, and if it gives an improvement over the ZF and the effect of a shorter rear axle.
One thing I can tell you is that T5 transmissions should not be too hard to find.
« Reply #16 on: September 06, 2005, 09:46:15 »
Tosh,
I am at about 2800 rpm at 60 MPH.  I don't hit 4000 RPM until over 90 MPH.  I had my speedo recalibrated to the new rear-end and is very accurate.  Sounds like you have a rear-end between the 4.08 and the 3.27  (I guess that would be the 3.46).  I think Cees has a mid-range rear end in his 280sl.
norton
« Reply #17 on: September 06, 2005, 10:47:34 »
"One thing I can tell you is that T5 transmissions should not be too hard to find"  Right you are Mike, The T5's are falling out of tree's on my side of town. :D
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
« Reply #18 on: September 06, 2005, 10:58:42 »
Mike Halleck
Chesterfield Mi
71 280SL
94 E320 Coupe
Well of course we are waiting to see your results.  Don't work under a tree if they are falling out of them on the East Side.
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #19 on: September 09, 2005, 17:23:32 »
Mike, if you can document what you learn with photos, you will have my undying gratitude.  I have been looking at T-5s and there are a several different top shifters for them.  One of the combinations should be right for our cars.  A T-5 is my 2006 target project.
Will you be using the MB bell housing?
'68 280SL 4-spd Coupe
« Reply #20 on: September 16, 2005, 07:52:51 »
Most of the original 5-speeds were 230SL/250SL and were sold in the European market, so they would probably have the 3.75 rear end, bringing it's RPM levels closed to the 4-speed with 3.27 rear end.
Chad
« Reply #21 on: September 16, 2005, 08:10:15 »
A pack of Marlboros fell out of a tree on me when I lived off Washington Square North for five years.  I remember it seeming not very out of place on that particular day.  Gave them to the next free spirit I played chess with at the SW corner of the park....  Never got hit by a T5, just not that lucky.
-CD-
1967 230SL, 113.042 10
1983 300TDT, 123.193
« Reply #22 on: September 16, 2005, 08:53:40 »
  5 speed Euro never came with a 3.75 differential.
  A 3:27 w/4 speed would equate to the 5ZF with the 3:92 in top gear.
 That is a common swap.
TR
« Reply #23 on: September 16, 2005, 09:47:32 »
Dalton -- Re swapping to a 3:27 w/4-spd; can you please comment on the effect this has on acceleration?  My question relates to Ed's observation, "obviously that would make it slower off the line".
I'm wondering if it really is much of an issue in terms of giving up some off-the-line performance.  1st gear has always felt a bit low to me anyway...so I have my doubts, but am not sure.
BTW, we are going to do something in this arena over the coming winter...Just not yet 100% certain what that will be.  But, naturally, our objective will be to have it all.  Meaning strong acceleration, good closeness, as well as comfortable, quiet cruising.  We'll also do our best to take the HP & torque curves into account.
Thanks.
Tom in Boise
« Reply #24 on: September 16, 2005, 15:36:08 »
TR
 Your chassis is a perfect candidate for the swap b/c you have a manual trans coupled  with more HP/Torque than the .042/043 for low end.
 You also already have the rear disc, so you do not have to worry about brake pressure mods.
