Author Topic: Replacing transmission hoses  (Read 3496 times)
« on: June 09, 2004, 01:17:02 »
Is it necessary to prime the system in any special way once I have replaced the two transmission hoses that run from the bottom of the  radiator, or can I just fit them, top up the system and run the engine to do the rest?
Re: Replacing transmission hoses
« Reply #1 on: June 09, 2004, 04:23:45 »
I did the latter, do make sure the fluid is at the correct level when done (warm engine, oil level at top of range). No special priming required AFAIK.
« Reply #2 on: July 06, 2004, 07:12:55 »
Thanks Cees.  All done, quite a simple job although oen of the new pipes is horribly close to the base of the rotating pulley from the alternator.  The pipe does have a protective 'spring' aroudn it an dit doesn't ahve much play so I guess the 8mm gap or so should be fine.
