Become a
Full Member
Emergency Contact List
General Discussion
Replacing transmission hoses
Topic: Replacing transmission hoses (Read 3497 times)
June 09, 2004, 01:17:02 »
Is it necessary to prime the system in any special way once I have replaced the two transmission hoses that run from the bottom of the radiator, or can I just fit them, top up the system and run the engine to do the rest?
Full Member
Platinum
USA, CA, Fallbrook
Re: Replacing transmission hoses
June 09, 2004, 04:23:45 »
I did the latter, do make sure the fluid is at the correct level when done (warm engine, oil level at top of range). No special priming required AFAIK.
Reply #2 on:
July 06, 2004, 07:12:55 »
Thanks Cees. All done, quite a simple job although oen of the new pipes is horribly close to the base of the rotating pulley from the alternator. The pipe does have a protective 'spring' aroudn it an dit doesn't ahve much play so I guess the 8mm gap or so should be fine.
General Discussion
