Author Topic: Vent levers - how to remove/install?  (Read 8925 times)
scoot
  • USA, CA, Altadena
« on: July 20, 2008, 16:30:28 »
The left and right fresh air vents that are opened and closed by the sliding lever under each of the two vents -- how do you remove / reinstall these levers?  I'm missing one and might be seeing a parts car today and am wondering how to get it out (and reinstall) if it is available....   thanks  Scott
Scott Allen
'67 250 SL (early)
Altadena, California
Paddy_Crow
Re: Vent levers - how to remove/install?
« Reply #1 on: July 20, 2008, 17:51:27 »
My recollection is that there is a spring catch on top of the lever where it joins the pivot inside. You can release it with a small screwdriver, just insert under the catch and pry up while pulling on the lever.
« Last Edit: November 14, 2008, 16:59:06 by vanesp »
scoot
  • USA, CA, Altadena
« Reply #3 on: July 21, 2008, 11:22:43 »
Unfortunately these threads only mention the question that I'm asking without ever answering it.  All I'm concerned about is the black pastic lever.  I don't want to take out the vent unless necessary.  Does the lever just slide in (with some sort of spring or something) or does the vent have to be removed/dismanteled in order to replace the black plastic lever?
Scott Allen
'67 250 SL (early)
Paddy_Crow
« Reply #4 on: July 21, 2008, 11:33:48 »
The vent does not have to be removed, although it is easier if you've already got them removed. But removing the vent is a royal PITA. You should be able to get a small screwdriver (I used a large jeweler's screwdriver) in where you see the plastic stick into the metal. Again, only going by recollection here, but there is a spring loaded catch that needs to be pried upward while the lever is pulled out. In the picture provided by 66andBlue, I believe the bright metal part is the catch. Seems like mine was either black or rusty, because I don't recall any bright metal in there.
If the levers don't work with ease, you'll probably want to lube the pivots with a light oil. I used a dry chain lube for bicycles.
« Last Edit: July 21, 2008, 11:35:22 by Paddy_Crow »
scoot
  • USA, CA, Altadena
« Reply #6 on: July 22, 2008, 14:12:30 »
Originally posted by naj
Do these levers belong to a 113?
http://cgi.ebay.de/Mercedes-W111-Coupe-SL-Pagode-W113-W108-W-111-113-108_W0QQitemZ300242577803QQihZ020QQcategoryZ42481QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
No.  They assumedly belong to the cars he has listed in his text (which include 190 SL pagoda) but they do not go to a 113 car regardless of his auction title including 113 in the text.
Scott Allen
'67 250 SL (early)
« Reply #7 on: August 09, 2008, 19:05:05 »
Since I had to reset the radial chrome vents I took better pictures to show how the lever is kept in place by a pressure clip.
However, it turns out - at least on my car - that the clip does not lock the lever in very firmly and it can be pulled out without the need to release the clip.
« Last Edit: August 09, 2008, 19:06:11 by 66andBlue »
jacovdw
« Reply #8 on: August 10, 2008, 08:50:16 »
...However, it turns out - at least on my car - that the clip does not lock the lever in very firmly and it can be pulled out without the need to release the clip...
Same here, just a firm yet gentle pull and out they pop
scoot
  • USA, CA, Altadena
« Reply #9 on: August 10, 2008, 10:22:20 »
Yippee.  I get it now, all works well.  thanks!
Scott Allen
'67 250 SL (early)
