Author Topic: Data Plate missing by left shock tower  (Read 6396 times)
perry113
  • USA, NY, Rensselaer
« on: March 09, 2008, 20:21:51 »
Has any one been able to take the data card (build sheet) which can be supplied by Mercedes Classic (refer to recent thread) and recreate the metal data card under the hood by the left side front shock tower.
I'm missing my metal tag. I would like to recreate a tag with the proper coding. I think I should be able to take it off the data card build sheet.
Here is is an example of a metal data tag (108 chassis) for reference along with the data card for my car.
1965 230SL White Ivory/Green
Download Attachment: 11304210012208 2.jpg
31.4 KB
Download Attachment: Maserati Bora 2006 037.jpg
197.1 KB
Peter Perry
1969 911T Tangerine
paulr
Re: Data Plate missing by left shock tower
« Reply #1 on: March 10, 2008, 00:59:35 »
there is a guy on ebay that recreates them
ebayaupurchases@gmail.com
Download Attachment: 113.044 280SL.jpg
91.48 KB
Download Attachment: 113.044.Actual.jpg
94.68 KB
Download Attachment: IMG_3472.JPG
29.27 KB
paulr
lovely 1970 280 SL
« Reply #2 on: March 10, 2008, 05:08:26 »
Looks like Paul and Pete are discussing two different plates...
Paul's looks like the plate on the passenger side (right side)of the Firewall of earlier cars and some later Euro cars...this plate is printed with information and has blank spaces to stamp the data about weight and seating capacity.
Peter's photo shows the plate attached to the top of the driver side (left side) fender...this is a blank embossed plate with no printed pattern. This plate shows major option codes, paint codes, job number, etc. but does not have weight or seating data.
Richard M
Klaus
« Reply #3 on: March 10, 2008, 09:45:43 »
This plate is described in detail in our Technical Manual, Data Cards and Codes, under "Body and Paint Number Plate".
In recreating this plate as accurate as possible, I would make it four lines:
420 493
670 H  670 H  6
113042 12   7
- 00591   03541
Klaus
1969 280 SL
« Reply #4 on: March 12, 2008, 05:12:05 »
I think the data plate Peter is referring to is the one that tells the color codes. It is screwed on the inner left side fender. I think if you can get the information you need Peter, the Gentelman who reproduces the Vin plates could make you one and then you are set.
I think the first step is finding what information was supposed to be on that plate. Does anyone have any commment as a way to use the Data card of vin number to trace what Peter is missing?
« Last Edit: March 12, 2008, 05:21:23 by 280SL71 »
68_white
  • USA, TX, Houston
« Reply #5 on: March 13, 2008, 16:36:27 »
Mine is missing also.
I have already decoded the numbers from the data card.
All I need is someone to emboss the numbers on a similar plate.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
perry113
« Reply #6 on: March 23, 2008, 17:16:07 »
HARRY
68_WHITE
Thanks everyone for your replies.
Harry,
Sounds like you figured out how to decode the factory data card and take that info needed to properly recreate your tag. That's what I need to do.
I have the tools to emboss them, however the numbers would be punched from the top. (The factory tags were punched from the backside with backwards punches).
Gernold at SL Tech said these reverse punches to his knowledge as of a year ago don't exist on the planet.
If you can help me properly decode the data for my car. I will gladly make one for yor car.
Here is my build sheet. I'm assuming everything is in the build card from the factory that can be somehow punched out on the metal tag located by the left front shock tower.
Thanks everyone. This forum is a joy to participate in.
Peter Perry
Peter's car 11304210012208
Download Attachment: 11304210012208.jpg
32.18 KB
Peter Perry
1969 911T Tangerine
68_white
  • USA, TX, Houston
« Reply #7 on: March 26, 2008, 09:18:37 »
Hi Peter:
I will get to my files in the next few days and post them.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
68_white
  • USA, TX, Houston
« Reply #8 on: March 30, 2008, 23:28:37 »
Peter:
I think I have the codes correctly for the card you showed.
Please send me an e-mail so that I may send you the info.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
