Author Topic: Rear Axle Removal  (Read 15346 times)
Rear Axle Removal
« on: December 08, 2007, 07:03:26 »
Hello All,
I know this may have been covered, but had trouble with an answer...
Tomorrow, the bodyshop will remove the front & rear axles.
Question: can the rear axle be removed without removing the compensating spring?  Can the rear axle be removed as a complete unit?
Any tips, suggestions?
 :) Thank You!
« Last Edit: December 08, 2007, 07:04:53 by bpossel »
Re: Rear Axle Removal
« Reply #1 on: December 08, 2007, 07:58:16 »
I believe it can.  Both of the SE axles I purchased came with compensating springs.  Joe is the real person to ask. I think the only concern is the the swing axle half opening to a point where the differential universal joint puts pressure on the outside edge of the diff housing.  I'm talking about the edge where the flexible boot connects the diff to the axle.  Here is a pic of what I'm talking about.
Download Attachment: diff case and right uni.jpg
44.48 KB
« Reply #2 on: December 08, 2007, 08:36:52 »
Bob, IMHO, yes and yes.  Is it more fun than king pin repair?  Non sequitor- How does the cam bolt in the top control arm get lubricated?  Not the threaded pin for caster.  The inside cam bolt- on the length of the inclosed bolt and the rotating 3/4" bushings at either end? :)  :?:
« Reply #3 on: December 08, 2007, 10:12:42 »
Just after re-assembly and before re-installation...
Download Attachment: Rear Axle and Differential on Bench Small.jpg
67.15 KB
...does this answer your question?
and in case you are asking about the front, again, after re-assembly and just before re-installation:
Download Attachment: Front Suspension Complete Small.jpg
73.31 KB
Mercedes-Benz Club of America
« Last Edit: December 08, 2007, 10:15:44 by mdsalemi »
« Reply #4 on: December 08, 2007, 13:18:57 »
Hello Bob,
As you can see from Michael's photo the rear end can be removed with the spring in place. However as Jeff pointed out, be carefull when allowing the differential to hinge all the way downward. The thin casting  can be cracked by the slide joint inside.
« Reply #5 on: December 08, 2007, 15:31:15 »
The camber cam bolt does not get lubed when the front end is greased because it is not a moving component of the suspension.
The caster pivot does because it is a working suspension component, so the grease from the zerk fitting is directed there. And yes, because the inner cam bolt doesn't get greased they usualy are stuck in place when it comes time to reset the front end alignment. I have had to burn out a bunch of them with a cutting torch to get the front ends apart.
Al Lieffring
66 230SL
« Last Edit: December 08, 2007, 15:33:04 by al_lieffring »
« Reply #6 on: December 08, 2007, 20:51:02 »
Thank You Al, Joe, Mike, Glennard, and Jeff!!!
« Reply #7 on: December 09, 2007, 17:17:35 »
Bingo, Al.  That cam bolt becomes a 'non moving' part! :twisted:  and no more camber adjustment.  We've got to invent an  adhesive as strong as rust.?!?!?
« Reply #8 on: December 09, 2007, 17:18:31 »
And no more caster!
