Author Topic: Bosch Spark Plug Wires  (Read 36638 times)
rb6667
« on: August 21, 2007, 13:50:06 »
Several auto parts stores tell me they have an application for a 68 280SL.  Any of you used the Bosch wires??  Any others that work better??
thanks rb6667
rb6667
Re: Bosch Spark Plug Wires
« Reply #1 on: August 21, 2007, 14:03:20 »
If it is the same Bosch wire set that I have, there are 5 straight resistor ends and one that is bent 90deg.
This is the set that in the past was sold for the M130v carbureted engines. The wires work just fine, but if you know that all 6 resistors were originally straight, it might bother you.
It hasn't bothered me enough to buy a second set just for the one resistor.
I have some Beru resistors, but they are yellow cad, the Bosch white cad plated. again an appearance issue, so I am running with the 90deg end on the #1 plug.
Al Lieffring
66 230Sl
Jones'n for a new gas tank
« Reply #2 on: August 21, 2007, 15:13:33 »
I am with you Al I am bugged by the bent resistor end as well. Maybe 5 of us can buy a set!
I have the original wires tucked away for originality. I like the Bosch but that bent one...
graphic66
« Reply #3 on: August 21, 2007, 15:35:49 »
I think those Bosch wires have the incorrect resistance for our ignition systems. From memory,  I think they are 5000 ohm and our cars require 1000 ohm.
« Reply #4 on: August 21, 2007, 15:38:54 »
Also it's possible that only that one bent one has a 5K ohm cap, and the others are correct with 1K ohm.
jameshoward
« Reply #5 on: August 21, 2007, 15:44:42 »
Had the same with the leads on my 230SL. The bent plug...
OK - stopped mid flow as Cees beat me to it. The bent one did have the incorrect 5K ohm cap whilst the others are the correct 1k ohm. These simply unscrew - ie there is a screw thread inside the cap. You can buy the 1k ohm beru caps in good shops (at least you can in Europe) so I just bought one for 4 euros, unscrewed the bent one, and put on the straight one. They are all correct for resistance on the right leads. A lot cheaper than a new set.
Agree with graphic66 - you need the minimum resistance. There's lots about this on the site.
James Howard
1966 LHD 230SL
« Reply #6 on: August 21, 2007, 16:56:00 »
I wouldn;t get too hung up on the resistance. It is just there for ignition noise resistance. I would however be concerned slightly if the bent one was 5k and the others were 1k. Higher resistance raises the firing voltage which makes a hotter spark which is good as long as it doesn't cause the spark to find a path to ground that doesn't involve the spark plug gap.
The 2 things to avoid like the plague(in my opinion) are carbon core wires and Champion resistor spark plugs. Carbon core wires are notorious for failing and when the resistance is in the wire the longer the wire the higher the resistance. Having 6 different resistances can greatly effect firing voltages between cylinders.
I know our plugs are not resistor plugs but I will say it anyway. Champion resistor plugs must be avoided at all costs. I used to train mechanics for BMW and one of the things I liked to do was buy a set of Champion resistor plugs and hae a student bring in a used set.
The new set would always be close to 5k resistance and the used set would always vary between 5 and as high as 27k ohms.
« Last Edit: August 21, 2007, 16:57:17 by Shvegel »
« Reply #7 on: August 21, 2007, 16:57:56 »
I found this while looking for sparkplugs.
http://www.stopshopanddrive.com/item.wws?sku=BSH008862&mfr=Bosch
« Last Edit: August 21, 2007, 21:17:11 by hauser »
rb6667
« Reply #8 on: August 21, 2007, 18:46:02 »
Ok, Let me see if I understand this, the bent one has higher resistance, but the straight ones are ok to use??  I guess one solution would be to purchase 2 sets of wires, and not use the bent one.  Anyone need some extra wires??  LOL.
rb6667
rb6667
« Reply #9 on: August 21, 2007, 20:53:57 »
The early W113 cars without the factory electronic ignition used the non-shielded 1,000 ohms spark plug ends #000 159 3210 and are often refered to as "far range".
The later W113 ignitions with the metal shielded spark plug ends "close range" #000 156 3010, #000 156 3210 were 5,000 ohms. I believe these were used on the later W113 cars with the factory electronic ignitions?
All the factroy wire sets used solid stranded copper wire which was tin coated  #110 159 1818 (by the meter). This was very good stuff and would not fail unless the insulation is shot. The wires misfire when the resistor ends go bad causing too much resistance, then the spark cannot get through or jumps and shorts causing a miss. Many original cars are still using the good factory original wire set after 40 years!  The wire resistance can be checked and the bad spark plug wire ends can be replaced (they screw off if the set is original). You use to be able to order new original wire by the meter (above) and "build a new set using your good ends and boots. Do not throw your originals away. Chances are you will never get set built and fitted as well.
Most of these cars have had the original ignition combinations scrambled up. If you have a standard ignition and your car is eating up points you may have a bad combination of coil and/or ballast resistor.
« Reply #10 on: August 21, 2007, 21:25:46 »
The 90 degree end is for cars with carbs. You need the 90 degree end to fit behind the distributor on those cars.
I've seen some of these Bosch wire sets and I'm not impressed. Carbon core coil wires, resistor ends on everything, 90 degree plug wire ends and 5,000 ohm resistors - in short, they're crap.
 It will make a difference if you have too many resistors in the circuit. Each one is at least 1,000 ohms with the rotor being about 5,000 ohms. The worst case would be carbon wires, resistor ends at 5,000 ohms and resistor plugs. You'd be lucky if it would even start. You'd would be quiet though....
1988 560SEC
« Reply #11 on: August 22, 2007, 06:02:18 »
Just so everyone is clear here...
1)  This 90 degree end with the 5K resistance, etc. is in a pre-assembled Bosch aftermarket kit that they sell EVERYWHERE.  It's only appeal is that it is cheap and available.
2)  There are so many parts suppliers out there and many of them sell the nearly-original Beru metal ends and or the nearly equivalent Bosch metal ends with the proper 1K resistance.  You simply have to build your own.
3)  There are many specific suppliers out there who will assemble the correct wire set with the correct parts.  I spent about 15 minutes in a google search a few years ago before I found a supplier.  His only problem was the wires were too long, but all the parts were right.  (Dan Caron shortened them all up for me!)
The only issue is that many of us balk when it comes to price.  The proper plug ends run $12 and more each; then you need the distributor ends, too, and the wire.  It isn't unusual then for a set to exceed $100; do the math.
When a pre-boxed Bosch set costs $38.50 (albeit with the wrong parts)at Jimbo's Foreign Auto Supply, it's hard to make the walk to $100+
If you do not show your car in a Concours, your opportunities expand greatly as you don't need Bosch or Beru parts--just solid wire and resistor ends.
Mercedes-Benz Club of America
rb6667
« Reply #12 on: August 22, 2007, 06:15:08 »
Very good information guys, that's what I was looking for.  I am a car guy, have 3 60's American Muscle Cars, so I'm used to making things work.  I'll see if I can find the correct spark plug ends, and make my own, using the correct wires, and ends.  I know those pre-assembled kits do not fit too well.  You always have to shorten some of them.
Thanks again for the great response.
rb6667
rb6667
« Reply #13 on: August 23, 2007, 10:22:39 »
The wire sets I sell are correct for 190SL's, pretty close for 230SL and not that close ( as far as lenght goes ) for 280SL but all are correct with the right distributor cap ends and proper resistance spark plug ends.
 All you need to do is cut the wire to the right lenght. Something you would be doing anyway if you bought a box of parts to make your own. I believe the proper pre made sets are the best choice and are resonably priced.
« Last Edit: August 26, 2007, 21:18:37 by Benz Dr. »
1988 560SEC
rb6667
« Reply #14 on: August 24, 2007, 12:33:55 »
Update!  With all this talk about Beru wires, I checked mine, and they are Beru.  Wires are blue in color.  Plug connectors have a gold Cad plating, with the wording Beru, West Germany.
 Reading some of your posts, it appears that these spark plug connectors can be re-used.  Is this correctZ??  How do you remove the wire from the spark plug connector?  I know I will have to get new distributor ends.
Thanks very much, rb6667
rb6667
psmith
« Reply #15 on: August 25, 2007, 00:36:20 »
Just for perspective or grins, I was quoted $500 for factory plug wires for my 98 Audi A6  [:0]
Pete S.
jameshoward
« Reply #16 on: August 25, 2007, 01:41:59 »
rb6667,
I managed to reuse my ends. The ones I had were connected to the wires by a small screw thread inside the cap. You simply unscrew the cap off the wire and then screw it into the new wire. Simple as that. Just read some of the posts here about which wire to get, esp those by Dr Benz and ja17 - lots of reference to carbon wire, what NOT to use, resistance (as little as poss) etc.
JH
James Howard
1966 LHD 230SL
« Reply #17 on: August 26, 2007, 21:16:14 »
The set I checked on the gold car I have in right now had a carbon core coil wire - the absolute worst place you could have a carbon core wire in the system. It chokes the spark down to nothing. The car would still run but the plugs were dark and the oil smelled like gas because it was so dilluted from improper cumbustion.
I removed the wire and used the caps and metal ends - they were new after all. I took out my ohm meter to show the customer and set it to 20K on the replacement wire which showed next to zero resistance. I moved it over to the carbon core unit and I couldn't even get a reading.
Imagine a lawn sprayer with a hose running over to your house. You have about 60 PSI coming out at the tap and the sprinkler runs great with a fountain 20 feet on each side.
Imagine what will happen if you step on the hose or put a kink in it. It will dribble out the other end. You still have 60 PSI pushing through the small crack but very little coming out.
Carbon core wires do the same thing. They cut the spark back a lot. If you have a modern 60,000 volt electronic system it probably won't matter but our cars run on 15,000 volts or less in some cases so every bit counts.
1988 560SEC
rb6667
« Reply #18 on: August 27, 2007, 05:53:53 »
I searched the archives and found that the original wires were black in color for the 68 280SL??  The ones I have are Blue...but they are Beru wires with the gold spark plug ends.
I do not see a screw holding those gold caps on.  Can these caps be re-used?  Benz DR.  Comments?
Thanks rb6667
rb6667
« Reply #19 on: August 27, 2007, 08:01:03 »
Thanks rb6667
rb6667
The 280 twin cam motors came with blue wires that had thicker insulation and 5k ohm resistors. The resistors usualy are marked with the resistance stamped on the metal shield.
The screw is inside, the risistor is twisted onto the end of the cable and the screw drives itself into the conductor in the middle.
Al Lieffring
66 230Sl
rb6667
« Reply #20 on: August 28, 2007, 18:00:00 »
Al, you are correct.  I checked the spark plug ends and they indeed are 5K Ohms. These wires are way too long also, the previous owner used wire ties to bundle them up which caused a miss.  I took the wires ties off, and no more miss.  Obviously crossfire at work here.
I'll be on the hunt for the correct 1K Ohm wires, and connectors.
Thanks again for all the great responses.
rb6667
rb6667
« Reply #21 on: August 29, 2007, 07:21:27 »
The NAPA web site shows in thier catalog metalic spark plug cable available in 100 foot rolls.
part #734803
The original cables were 7mm in diameter and had black insulation.
Napa also lists blue 7mm metalic cable with high temp silicon insulation.
Al Lieffring
66 230Sl
« Last Edit: August 29, 2007, 07:26:02 by al_lieffring »
rb6667
« Reply #22 on: August 29, 2007, 16:31:20 »
Thanks for the leg work Al.  I'll see if there is a way this can be purchased by the foot as needed.  100ft would handle a lot of cars.  Group purchase anyone??
rb6667
rb6667
« Reply #23 on: August 29, 2007, 18:05:43 »
I found bulk wire from Beru.  I don't know if it's the correct wire or not.
http://www.kingsborne.com/beruwire.htm
« Reply #24 on: August 29, 2007, 20:48:00 »
Hello Hauser,
The Beru is "copper stranded" so it looks like the stuff! The Napa "metalic" cable of Al's may be the right stuff also.
Here are some original ends;
Download Attachment: ignition.JPG
33.98 KB
« Last Edit: August 29, 2007, 21:00:07 by ja17 »
