Author Topic: throudle/idle control adj.  (Read 4944 times)
james
« on: August 19, 2007, 14:44:48 »
let's not discuss who I got here.......?? let's just say I need help badly...
I have disonnected the throudle control on the side of the pump and
now I am way out of adjustment???? the spring is off the whole thing
is a mess. I have no one to help, except a haynes manual.
Please help. I need to get this arm back on and the shaft it rides on
in the correct position.
Help Jim
Jim
Re: throudle/idle control adj.
« Reply #1 on: August 19, 2007, 15:55:26 »
Jim,
Sorry to hear about your trouble.  Here are some pics I took of my car. I hope they help.  I've not taken the linkage off the pump myself but I'll be happy to help all I can.
Good luck
Download Attachment: linkage1.jpg
66.4 KB
« Reply #2 on: August 19, 2007, 15:55:59 »
Download Attachment: linkage2.jpg
63.43 KB
« Reply #3 on: August 19, 2007, 15:56:30 »
Download Attachment: linkage3.jpg
62.31 KB
james
« Reply #4 on: August 19, 2007, 16:10:10 »
I am affraid I did not make myself clear. the arm that is attached to the shaft, going into the pump (like the one's you have taken photo's of) is off? and how do I determaine how to set the correct postion to attach it. and how do I know how to put this shaft back into the correct position?
Jim
Jim
« Reply #5 on: August 19, 2007, 16:19:40 »
Okay, understood.  Let me look around for some info and I'll get back to you.
« Reply #6 on: August 19, 2007, 18:10:08 »
Send me a PM with your email address and I'll send you a pdf file about linkage adjustments for our cars.  It's too big to send here.
james
« Reply #7 on: August 20, 2007, 05:50:34 »
Jeff my e-mail address is j.collins60@verizon.net
thanks for your help.
Jim
Jim
« Reply #8 on: August 20, 2007, 14:50:19 »
Done!  Good luck!
james
« Reply #9 on: August 20, 2007, 16:17:57 »
thanks to everyone......I have removed my pump and discovered the problem. I think it is now fixed and I will reinstall it tommorrow. wish me luck.
thanks again Jim
Jim
« Reply #10 on: August 20, 2007, 18:19:05 »
Yu can't fix this yourself despite advice that says you can. It's one of those things that you should never touch like a nest of killer bees.
Take the pump off and have it calibrated or rebuilt depending on what it needs.
1988 560SEC
