Author Topic: under body question  (Read 9112 times)
merrill
under body question
« on: June 12, 2006, 11:53:00 »
So, I was working on the car this weekend, and happend to look in the front drivers wheel well and saw what looked likt a leaf or something stuck up there.
reached up and felt what seemed like tape, gave it a pull and sure enough there was a lenght of tape.
I guess it was covering where the wheel well, fender came together.
now instead of what appeard was one smooth arch I can see where the metal sections are joined together.
my question is ,  should I put new tape there? is there a cover missing?  I looked at all the photos I could find and didn't find any that showed me that upper wheel well area.
just want to make sure I fix this correctly
thanks in advance
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: under body question
« Reply #1 on: June 12, 2006, 12:16:11 »
Think you may be missing the splash guards:
http://index.php?topic=5257,guard
Item 12 on the SLS catalog front fender picture
« Last Edit: June 12, 2006, 12:26:21 by naj »
merrill
« Reply #2 on: June 12, 2006, 14:30:27 »
naj,
no this is not the spash guard, the tape was covering the mating areas  above the wheel well and the front fender.
imagine looking at the front shock in the wheel well up top. then looking toward the engine bay I can now see the mating of the wheel well, front panel and whatever constitutes the side wall of the engine bay.
thanks
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #3 on: June 12, 2006, 15:31:54 »
These any help?
Download Attachment: 06Esn069.JPG
17.78 KB
Download Attachment: 06Esn070.jpg
24.26 KB
Download Attachment: 06Esn071.jpg
20.4 KB
merrill
« Reply #4 on: June 12, 2006, 17:24:39 »
Naj,
yes!  looking at the last photo, you can see where the fender curvs back down on the inside, and mates up to a boxy item.
on my car the tape continued the curve from the fender down to the wheel well.  thus the area was "smooth"
guess the tape was not supposed to be there?
thanks
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #5 on: June 12, 2006, 21:20:49 »
Was the tape right under the box section ("A") or down lower ("B")?
Download Attachment: TapeHere.jpg
24.69 KB
merrill
« Reply #6 on: June 13, 2006, 07:11:53 »
Rodd,
The tape is about 5' wide,  so it covered A and went up and mated with the fender where it mates with the box section at A
Is this normal?
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Vince Canepa
« Reply #7 on: June 13, 2006, 08:19:31 »
The tape is not original.  My guess is that someone put it there to stop moisture holding debris from collecting atop the longitudinal box section (a).  I have seen rust start there.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #8 on: June 14, 2006, 10:53:21 »
You would not believe how much dirt & grime were packed into that small space above the box section on my car when I bought it.  I highly recommend that everyone check this area on their car if they have not done so in the past.
« Reply #9 on: June 14, 2006, 11:43:37 »
I concurr with Rodd on this being one of the weak spots of the SL.
I have seen my share of rust and nasty accumulations of dirt/mud/ rust/ bondo/ and whatnot packed into this area.  How does one clean it out?  Me: a wire brush to break up the big hard encrustations and then a water hose with a trigger nozzle on the end to give more pressure to wash it all clean.
I usually do the high pressure wash underneath and in the wheel wells on every car right after a run in the salt roads(winter) and puddles (rest of year).  I am continually amazed at the stuff that washes out from under the crevices.  Another area to clean out real well on the SL in addition to the underside and wells is the panel between the tank and license plate panel.  Many cars had rust bubbles forming in this panel.
Walter Klatt
1967 220Sl-diesel
1963 230SL-gas
« Reply #10 on: June 14, 2006, 12:33:30 »
The area on top of that box section is hard to see, so if you inspect by feel, wear gloves.  If there is significant rust there and you don't protect your fingers, you may shred them.
« Reply #11 on: June 19, 2006, 05:56:42 »
OK,
Another 'underbody question'  ...
My car has a hole through the floor pan behind the right hand side seat. The hole is in the centre of what would be the foot well for the rear seat passengers if there was room so I figure it is not seat belt related.
From below this hole is close to the outside rubber exhaust mount ring.
Something has either been removed or fallen out.
I don't remember seeing this hole previously.
Any clues as to what this hole was used for?
Thanks, all info gratefully received.
« Reply #12 on: June 19, 2006, 07:25:02 »
Is it this 'mother in law' thing or a n other  :?:
http://www.sl113.org/forums/uploaded/naj/200653171139_06Esn084.JPG
« Last Edit: June 19, 2006, 07:26:23 by naj »
« Reply #13 on: June 19, 2006, 07:50:44 »
Naj,
That looks like a toilet bowl mounting ring!
« Reply #14 on: June 20, 2006, 06:16:05 »
Hey Naj,
No in what would be the foot well directly behind/under the seat not under the shelf.
It is a bolt size hole.
LOL at Rodd
« Reply #15 on: June 20, 2006, 06:36:30 »
Hi, Bob,
Don't think there should be a hole in the middle.
Didn't see one on the 230 when I had the mats out recently.
Is it in this pic.? (Finn's 230)
 http://www.sl113.org/forums/uploaded/mille/200572517711_P4201020.JPG
« Last Edit: June 20, 2006, 06:37:54 by naj »
« Reply #16 on: June 20, 2006, 06:47:39 »
Hi, Bob,
hey Naj,
The exhaust rubber ring brackets are missing from that pic but I have circled the area I think is relevant.
The hole is on the sloping part of the underbody.
thanks
Download Attachment: underfloor2.JPG
65.66 KB
« Reply #17 on: June 20, 2006, 07:08:06 »
Do you have seat belts?
I thought the buckle strap attaches in this area...
« Reply #18 on: June 21, 2006, 05:18:03 »
Hey Naj,
Yes the seat belts are installed correctly.
This hole could have always been there but recently my car was caught out over night in a deluge of rain.
As it isnt water tight around the drivers' window seals, the carpet behind the seat was soaked. It was glued down and so for the first time I saw that floor area with the hole.
I try not to be a worry wort.
Does your RHD car have a hole near the exhaust hanger bracket?
I am going to find a body plug and then I can forget about it and start to think about more important things like my front brakes and suspension.
Again many thanks
