Author Topic: Hazard flasher switch  (Read 5328 times)
Ian45
« on: May 10, 2006, 05:41:32 »
I have occasionally seen for sale on Ebay a hazard flasher switch/knob supposedly for the W113 or other models of that era. It appears to be a twist knob similar to the heater blower knob fitted to the W113 and on the back of it has the prongs ready to push straight into a connector block.
Does anyone know if it was a genuine optional extra, where on the dash it would fit on the W113 and whether the wiring and connector block will already be in place for it behind the dash somewhere ?
Ian
Derby,England
Re: Hazard flasher switch
« Reply #1 on: May 10, 2006, 06:09:57 »
Ian,
Yes, the US-spec cars were fitted with a Hazard Switch on the dash at some point. I believe they all got a hazard switch at some point. Take a look at the attached photo. Note the red knob to the left of the steering wheel:
Download Attachment: 18_4.JPG.jpg
70.19 KB
« Last Edit: May 10, 2006, 09:15:23 by Douglas »
« Reply #2 on: May 10, 2006, 12:05:00 »
Hi, Ian
To add Hazard Warning to a 250 SL you would need the complete assembly which includes a heavier duty flasher unit and switch with knob, and it would have to be wired in. When you pull the knob to switch them on, the power to the normal flasher unit is cut-off.
Here's a picture of a Hella unit I added to my 280 SL. It is mounted under-dash (top RH corner)
Download Attachment: Spkr12.JPG
41.79 KB
p.s: Ignore Jack's wiring  :oops:
« Last Edit: May 14, 2006, 08:09:15 by naj »
« Reply #3 on: May 10, 2006, 12:14:41 »
Hey Naj, I was about to ask why you put a speaker in the Trans. tunnel...  :|
« Reply #4 on: May 10, 2006, 12:41:05 »
'HOT' air makes better sound [:p]
Ian45
« Reply #5 on: May 11, 2006, 06:34:27 »
Thanks Naj and Douglas.
One of next winter's projects is to have the dash to pieces to investigate a non-moveable heater lever and a rattle from behind the clock, so I'll probably consider a hazard flasher switch then.
Ian
Derby,England
« Reply #6 on: May 11, 2006, 14:17:07 »
Ian,
I think I have a template from one of the many MB technical manuals in my collection.
Remind me again if I don't reply by next week.
Walter Klatt
1967 220SL-diesel
1963 230SL-gas
« Reply #7 on: May 17, 2006, 09:31:53 »
Ian,
I found the write up on the installation of the flasher from the MB technical book.
It is several copies and don't want to scan them as they might be copyrighted.  I would be willing to make copies and send them to you via post.
Let me know and email me off list with your address.
Walter Klatt
1967 220SL-diesel
1963 230SL-gas
