Author Topic: Lucky Car  (Read 10469 times)
Tom230sl
Lucky Car
« on: October 06, 2005, 13:04:42 »
A number of you expressed interest or had questions about my resto and did not want to hijack the "winter projects" topic. Sorry if i'm not able to post as often as I would like.
#012277 European delivered (Duisbreg Germany) then imported to US
NOTE:  Still need original small trunk mat and Bosch horn tags (set) help anyone !
This restoration has taken approx. twelve years, it was on hold for a  lot of those. Yes, costs are into the six figures, and I did most of the work! Originally the car was brought to Scott Restorations in L.A. just in time for them to go out of business.  I pulled the car and had someone strip and rebody, however I was unhappy with their work so I pulled the car again and did most of the work myself.  There was a good deal of rust removed (this was a lucky car, should have been parted out) everything on the car was removed and stripped to bare metal, and corrected. The entire underside was stripped, primed, seam sealed, and undercoated using MBZ material.  All chrome went to Christensen Plating in L.A. (the best, but took 4 months). The engine long block rebuild by Metric Motors in Canoga Park, CA. included balancing crank/flywheel for the manual to auto trans conversion (wife can't drive a manual -- she crashed this car during the test drive) they (and gernold at SL Tech) also helped me sort all the pulley's etc for the AC. I did all the component refinishing (bead blasting, cleaning, and painting of various parts) sent to Van Nuys Plating for cad. The body panels tweeked and paint prep was done by Rocky at Johnson Classics in Riverside CA (subbed by Strauss).  Paint and the final assembly is currently being handled by Bell Strauss Auto Care (formerly Bruce Strauss Auto Care) in Costa Messa, CA.  They laid down the beautiful two stage paint for exterior and single stage used on engine compartment and under car.
Not perfect, just done the way I wanted it.
Download Attachment: a.jpg
78.73 KB
Download Attachment: b.jpg
69.89 KB
Download Attachment: c.jpg
62.52 KB
Download Attachment: d.jpg
76.99 KB
Download Attachment: e.jpg
82.36 KB
Download Attachment: f.jpg
74.57 KB
Re: Lucky Car
« Reply #1 on: October 06, 2005, 15:41:32 »
People like you deserve The Pagoda Medal of Honour. Makes my winter projects pale by comparison. On behalf of your lucky car: Thanks!
Re: Lucky Car
« Reply #2 on: October 06, 2005, 16:29:56 »
Nice Tom!
Yes you have a very lucky car to have an owner like you!
« Last Edit: October 06, 2005, 22:24:03 by ja17 »
Kenneth Gear
  • USA, VA, Fairfax Station
Re: Lucky Car
« Reply #3 on: October 06, 2005, 16:45:01 »
Outstanding!  I am very impressed.  I wish I had your talent and patience.
Ken G
1971 280 SL
Silver/red
Ken G
1971 280 SL Silver/red
Re: Lucky Car
« Reply #4 on: October 06, 2005, 17:02:02 »
Tom: All I can say is: "Wow, what a lucky car"
iceberg
Re: Lucky Car
« Reply #5 on: October 06, 2005, 17:24:09 »
Amazing...lost for words.....Amazing
Khurram Darugar
Re: Lucky Car
« Reply #6 on: October 06, 2005, 18:13:22 »
WOW!
What an insipiration to any restorer!
Re: Lucky Car
« Reply #7 on: October 06, 2005, 19:29:24 »
Spectacular, Tom. It really thrills when I see someone execute at this level of detail. Can't wait to see the finished product; please keep all of us entertained (via text and photos) with the final steps.
You must be very pleased with the results of your patience.
1973 911S
2004 A4 3.0
2006 GS430
Chad
Re: Lucky Car
« Reply #8 on: October 06, 2005, 21:38:10 »
Awesome man!
-CD-
1967 230SL, 113.042 10
1983 300TDT, 123.193
Re: Lucky Car
« Reply #9 on: October 06, 2005, 22:07:53 »
A job like this gives the owner a much higher level of pride and joy.  There aren't very many owners that would tackle a project such as this.
Congrats! Tom! On a job well done!
Re: Lucky Car
« Reply #10 on: October 07, 2005, 05:41:27 »
Tom,
Stunning work my friend!  Some of your photos look like my set, as I had my car restored nearly to your level in 1999-2001.
Regarding your horns--I developed a way to create perfect Bosch horns that will befit the fine car you have.  Since you do all this kind of work yourself, here's the plan.
1)  Remove your horns, disassemble, and set aside all but the two halves of the case.  You do need to pay attention to some rivets which need to be drilled out.
2)  Bead blast the case halves, paying attention not to destroy threaded components.
3)  Powder coat to glossy black.
4)  After cleanup, re-fit the electrical block on the back half.
5)  Obtain a new set of Bosch horns, hi and lo tones.  They can be had at most Bosch dealers, or look under all the mail order parts guys for a set for a 300SEL.
6)  Using a good quality paint, spray the FRONT parts of your new horns so they too, have a glossy black finish.
7)  Using your best tools and imagination, install these new horns INSIDE the rear case of your old horns.  Yes they fit.  You can use a strip of steel, and existing holes in the case.
8)  You need to take the new horn's power to the power block in the old horn.  Once you have it all apart it will be obvious.
9)  Use either foam tape as a gasket, or fabricate a gasket out of cardboard or craft foam for the two case halves.
10)  Obtain a horn kit from Stoddard Imports http://www.stoddard.com/ they sell a horn dress up kit which consists of new tags and new hardware.  Not 100% perfect but pretty darn close.
11)  Reassemble.
Your horns will be so beautiful you may not want to install them but for shows!  I'm partially through this project myself.
gwuisman
  • Keep it simpel
Re: Lucky Car
« Reply #11 on: October 07, 2005, 09:30:15 »
Not only lucky car but also lucky you with so much character to complete such a project.
Gerard Wuisman
1970 280sl
« Last Edit: October 07, 2005, 13:54:37 by gwuisman »
Tom230sl
Re: Lucky Car
« Reply #12 on: November 21, 2005, 10:49:16 »
progress update...
Download Attachment: PA110071.jpg
47.5 KB
Download Attachment: PA110076.jpg
50.32 KB
Download Attachment: PA190110.jpg
45.09 KB
Download Attachment: P1010032.jpg
56.15 KB
Download Attachment: P1010038.jpg
41.89 KB
Download Attachment: PA190116.jpg
53.74 KB
Download Attachment: P1010085.jpg
40.16 KB
Download Attachment: PB180005.jpg
50.76 KB
Download Attachment: PB180014.jpg
35.05 KB
Download Attachment: PB180023.jpg
48.35 KB
Download Attachment: PB180081.jpg
51.04 KB
Download Attachment: PB180093.jpg
57.45 KB
terry shores
Re: Lucky Car
« Reply #13 on: November 21, 2005, 11:46:50 »
YOU HAVE FORTITUDE!!!!
Chad
Re: Lucky Car
« Reply #14 on: November 21, 2005, 12:41:59 »
An absolutely beautiful car!!!
-CD-
Re: Lucky Car
« Reply #15 on: November 21, 2005, 13:10:55 »
Tom:
Your project looks awesome. I'll bet many in this group are at least as excited about it as you must be.
1973 911S
2004 A4 3.0
2006 GS430
Re: Lucky Car
« Reply #16 on: November 21, 2005, 16:22:56 »
Fantastic! I can only ever aspire to such perfection! Now here's something to dream about...
WAQAS in Austin, Texas
