Author Topic: Drive shaft replacement  (Read 252 times)
FresnoBob
  • USA, CA, Fresno
« on: October 08, 2025, 18:08:14 »
The transmission end flange of my 1966 Automatic 230 SL driveshaft failed and I'm not sure if it can be repaired or I need a replacement.  Has anyone experienced this before?  Any suggestions?
Bob Comstock
1966 230 SL Euro Auto
2017 AMG C43 Cabriolet
dirkbalter
  • USA, CA, Corona
Re: Drive shaft replacement
« Reply #1 on: October 08, 2025, 18:20:00 »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #2 on: October 08, 2025, 21:20:51 »
Hi Bob,
Give these guys a call. They were able to repair my driveshaft once and rebuild it once… worth a shot.
https://www.driveshafts.com/Performance-and-Specialty-Cars
FresnoBob
  • USA, CA, Fresno
« Reply #3 on: October 08, 2025, 22:16:32 »
This is a picture of the damaged flange.  According to the SLS diagram, I have an early 230 SL.
Bob Comstock
« Reply #4 on: October 09, 2025, 04:14:02 »
If it's regular steel it can be repaired relatively easily by a competent fabricator.
« Reply #5 on: October 09, 2025, 15:28:03 »
Should be fairly easy to locate a replacement driveshaft but in any event any competent driveshaft o/haul shop will probably have be able to replace the yoke (the failed part).
FresnoBob
  • USA, CA, Fresno
« Reply #6 on: October 09, 2025, 23:27:41 »
The amazing Joe Alexander had a spare flange, so I'm in business.  The local drive shaft shop is fully capable of replacing the flange and then balancing both shafts together.
Thanks for the recommendations!
Bob Comstock
