Become a
Full Member
Emergency Contact List
Wanted To Buy
Drive shaft replacement
Topic: Drive shaft replacement (Read 256 times)
FresnoBob
Full Member
Senior
USA, CA, Fresno
October 08, 2025, 18:08:14 »
The transmission end flange of my 1966 Automatic 230 SL driveshaft failed and I'm not sure if it can be repaired or I need a replacement. Has anyone experienced this before? Any suggestions?
Bob Comstock
1966 230 SL Euro Auto
2017 AMG C43 Cabriolet
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: Drive shaft replacement
October 08, 2025, 18:20:00 »
if you are talking about the this part:
https://www.sls-hh-shop.de/de/mercedes-230-280sl-w113/35-40-41-hinterachse-raeder-kardanwelle/40-raeder-und-kardanwelle
mine was broken and I replaced it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pagoda SL Board
Platinum
USA, NC, Davidson
Reply #2 on:
October 08, 2025, 21:20:51 »
Hi Bob,
Give these guys a call. They were able to repair my driveshaft once and rebuild it once… worth a shot.
https://www.driveshafts.com/Performance-and-Specialty-Cars
FresnoBob
Full Member
Senior
USA, CA, Fresno
Reply #3 on:
October 08, 2025, 22:16:32 »
This is a picture of the damaged flange. According to the SLS diagram, I have an early 230 SL.
Bob Comstock
Full Member
Platinum
USA, CA, Fallbrook
Reply #4 on:
October 09, 2025, 04:14:02 »
If it's regular steel it can be repaired relatively easily by a competent fabricator.
Vendor
Platinum
United Kingdom, England, Richmond
Reply #5 on:
October 09, 2025, 15:28:03 »
Should be fairly easy to locate a replacement driveshaft but in any event any competent driveshaft o/haul shop will probably have be able to replace the yoke (the failed part).
Stick
www.colinferns.com
FresnoBob
Full Member
Senior
USA, CA, Fresno
Reply #6 on:
October 09, 2025, 23:27:41 »
The amazing Joe Alexander had a spare flange, so I'm in business. The local drive shaft shop is fully capable of replacing the flange and then balancing both shafts together.
Thanks for the recommendations!
Bob Comstock
Wanted To Buy
