Author Topic: Tank to fuel pump  (Read 123 times)
CJHenderson
  • USA, AR, Benton
Tank to fuel pump
« on: September 13, 2025, 17:34:18 »
Checking to see if the tank to fuel pump hoses is correct. My photos from when I stripped the car down isn't very good at all.
1950 MG-TD
Re: Tank to fuel pump
« Reply #1 on: September 13, 2025, 22:40:11 »
It looks normal, I think... I have an in-line fuel filter installed on it. You need to have at least a screen in the pump fitting. I usually see the fuel lines have fabric lining, so you may need to make sure if the hose you have is a fuel hose and not some generic hose.
The other hose, pump to fuel line, is attached to the floor with a clamp (picture).
Lugnut
  • USA, FL, Bradenton
« Reply #2 on: September 13, 2025, 23:19:46 »
The hoses are different diameters for each attachment point, so what you’ve done looks right. The pump is facing the right direction, only thing missing is a fuel return line clamp. Also make sure there is no interference with the axle when the car is on the ground.
