Author Topic: The hose attached to the front of crank case  (Read 239 times)
CJHenderson
  • USA, AR, Benton
« on: September 10, 2025, 16:33:17 »
The hose attached to the front of crank case, where does it connect to?
« Last Edit: September 10, 2025, 20:26:46 by CJHenderson »
1950 MG-TD
BHap
  • USA, PA, Pittsburgh
Re: The hose attached to the front of crank case
« Reply #1 on: September 12, 2025, 01:19:19 »
I think that tube comes from the plastic fuel evaporation tank in the trunk which vents the fuel tank.  Directs fuel vapor from the gas tank back into the engine - so part of the emissions control.  This setup started in 1970 and replaced the "atmospheric" venting setup in earlier cars.
Bob Happe
Pittsburgh, Pa
CJHenderson
  • USA, AR, Benton
« Reply #2 on: September 12, 2025, 15:53:32 »
Thank you for your reply, your advice helped me greatly.
1950 MG-TD
