Author Topic: Position of the crankshaft seal  (Read 5964 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: August 24, 2025, 05:17:02 »
Hi gents
I was working under my car and noticed that the crankshaft seal isn’t sitting flush with the crankcase. There’s no sign of an oil leak, and I can see some sealant around it. What’s your opinion on this? (Please, only from those who really know 😁)
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
Figoulu
Re: Position of the crankshaft seal
« Reply #1 on: August 24, 2025, 18:39:53 »
Nobody to help me ? 😅
1965 230 SL
yves
  • France, Poitou-Charentes
« Reply #2 on: August 24, 2025, 19:36:05 »
Sorry Francois……! I can’t help you but am on the professional answer…soon?
Figoulu
« Reply #3 on: August 25, 2025, 04:48:16 »
In case you have some time to spare if you could just take a look at yours and possibly post it here, it would ba great 👍
1965 230 SL
WRe
« Reply #4 on: August 25, 2025, 06:28:08 »
the sealing ring must sit flat on the engine block.  Yours has moved too far outwards . Perhaps the inner Borgmann ring has shifted outwards too.
Attached are two pictures from the German Pagoda Forum.
...WRe
Figoulu
« Reply #5 on: August 25, 2025, 07:38:49 »
...WRe
thanks  !
I noticed in the first picture that the seal doesn't appear to be 100% flush, but the angle of the photo might be a bit misleading…
If that’s really the case, I suppose it could be easily repositioned? I don’t think the seal has moved since it was installed.
I've asked the mechanic who did the work and I'm waiting for his response, but I wanted to get your advices in the meantime.
Anybody else to complete ?
1965 230 SL
WRe
« Reply #6 on: August 25, 2025, 07:58:40 »
In my first picture, too much additional sealant was probably used.
The "collar"/edge should fit tightly, if there is one (different parts).
su8pack1
  • USA, PA, Barto
« Reply #7 on: August 25, 2025, 12:44:42 »
I just replaced mine last month.
1984 300CD
1987 190E 2.6
1988 190D 2.5
Figoulu
« Reply #8 on: August 25, 2025, 13:45:40 »
And how was the seal against the crankcase ? Flush or not ?
1965 230 SL
« Reply #9 on: August 25, 2025, 15:21:52 »
Seal should be fairly even with the crankcase. Crooked seals can leak.
« Last Edit: August 25, 2025, 17:05:19 by Benz Dr. »
Figoulu
« Reply #10 on: August 25, 2025, 15:27:10 »
My mechanic said that I need to push it further so that it sits flush with the crankcase.
That means removing the radiator, fan, and belts (alternator, water pump, power steering pump...), then proceeding to remove the damper.
I guess I’ll need to replace the carnkshaft screw when putting everything back together.
Well... I’m a bit tired and now I understand why I prefer doing things by myself. At least if I’m disappointed with my work, I still save money.:D
1965 230 SL
su8pack1
  • USA, PA, Barto
« Reply #11 on: August 25, 2025, 16:35:44 »
This was my original before removing.
1984 300CD
1987 190E 2.6
1988 190D 2.5
Figoulu
« Reply #12 on: August 25, 2025, 18:59:25 »
Anybody to guide me to block the engine and remove the damper ?
Would you engage the gearbox ?
Would you put a rod thru the camshaft gear ?
1965 230 SL
« Reply #13 on: August 25, 2025, 21:02:36 »
I use an air impact gun. It should rip it out easily without turning the crankshaft. Then I use a 6 inch extension behind the front balance weight and use the extension to block any movement while I torque the screw down while installing. Be sure to use a bit of oil on the threads of the screw and also on the washers. Gives a much better torque down with lubrication.
Figoulu
« Reply #14 on: August 26, 2025, 07:41:40 »
Hi Dr Benz
Thanks for your feedback !
Would you change the crankshaft screw , It seems mandatory for me...
1965 230 SL
« Reply #15 on: August 26, 2025, 15:38:28 »
One thing to point out regarding seal material. The brown ones are most likely to be a high temperature material similar to the trade name Viton. The black seal will most likely be a Nitrile. The Viton will have better properties and is recommended. There are a lot of different versions of these seals.
« Reply #16 on: August 26, 2025, 19:33:56 »
Hi Dr Benz
[/quote
I never do. YMMV
Figoulu
« Reply #17 on: August 30, 2025, 13:29:13 »
The best I could do 😅
The seal is slightly damaged around its edges, but I think it should be fine…
« Last Edit: August 30, 2025, 13:33:23 by Figoulu »
1965 230 SL
« Reply #18 on: August 30, 2025, 14:11:36 »
That looks great and catching that it didn't look right was a good call.
Looking at where the lip seal meets the crank, I suspect that you would likely have found a disappointingly large pool of oil under the front of your freshly rebuilt engine after your first drive. As discovered, the lip seal was likely sealing against air!
Even an experienced person can make a mistake and not catch it by failing to double-check completion of an assembly step.  Hopefully your rebuilder learned a lesson and will double check his work with more rigor in future.
Cheers!
Figoulu
« Reply #19 on: August 30, 2025, 17:36:38 »
Thanks Mike for your positive comment
Over the years, I’ve learned to stay calm in situations like this when dealing with mechanics. I wouldn’t say this was some small, hidden issue that no one could have noticed... At the very least, if you’re getting paid, you should deliver a complete and quality-checked job. But as I said, I stay calm—otherwise, nothing good would come out of the situation.
He’s lucky I’m not easily worried by issues like this and could manage, but a rookie would have every reason to be confused and disappointed. Anyway, I’ve learned...
1965 230 SL
« Reply #20 on: August 31, 2025, 06:27:54 »
Where can I buy this Viton seal for my 280SL? Vendor name? Part number?
Thanks for any pointers.
Figoulu
« Reply #22 on: August 31, 2025, 09:24:50 »
I have no idea as the mechanic did the overhaul himself…
Does niemoller or Mercedes is out of stock ? I believe for those who can get the spec, that it’s available out of the official branded dealer as Mercedes nor niemoller make their seals.
1965 230 SL
Figoulu
« Reply #23 on: August 31, 2025, 09:29:54 »
So… back to the garage
Today as everything is back together I was planning to begin the tuning of the air/ fuel mixture basing my work upon this very useful forum of course…
As I was planning to have the engine ready at its running temperature an oil leak appeared…
Hard to see as is but probably between the engine and the gearbox…
What would you envisage ?
If this is the same sort of seal as the last one I would probably have to remove engine/ gearbox together? (Once again)😁😁
Thanks for your feedback 👍
1965 230 SL
« Reply #24 on: August 31, 2025, 17:02:34 »
Ouch, if it's engine and not transmission oil and it's not coming from the top somewhere, I'm afraid it's the rear main seal. If so, would need to separate the gearbox from the engine, which can stay in the car AFAIK.
