Author Topic: Re: Finding electrical plug PT2  (Read 2158 times)
CJHenderson
  • USA, AR, Benton
« on: August 20, 2025, 19:54:27 »
Have this second 6-pin plug that seem to not have anywhere to hook up to. These colors are BW, BG, BWG, RY, Brown, and another BWG. When looking at the color schematic I see block 18 which is for Direction Signal Transmitter which shows a 6-pin plug. My question is which block is for the Hazard module.
1950 MG-TD
lpeterssen
  • USA, FL, Miami
« Reply #1 on: August 21, 2025, 00:41:12 »
Dear Mr Henderson
The lines shown on that 6 pin connector are exactly the ones on a hazard relay, but they are in reversed order.
Shown below the correct pin assignment for a Bosh hazard relay.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
« Reply #2 on: August 21, 2025, 10:39:35 »
The lines are reversed upside down.
The clue that this is a a hazard relay 6 pin plug is the presence of those BLACK/WHITE and BLACK/GREEN lines which correspond to the LEFT and RIGHT TURN SIGNALS respectively.
The BLACK / RED/ green is the T15 feed for the relay (blinker function) and the RED/YELOW IS the T30 feed for the same relay (hazard function)
Finally the BLACK/WHITE/GREEN is the BLINKER OUTPUT Named “49a”
Have a bosch hazard relay in hands as model shown on picture on previous post and match lines with the pin labelling on the unit.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
CJHenderson
  • USA, AR, Benton
« Reply #3 on: August 21, 2025, 14:30:38 »
The Hazard switch is not Bosch it's from SLS in Germany. I'm reinstalling the old unit and see what happens. I do think that when the harness was built that someone installed the wrong terminal plug, I'll look for one that lets me install the wires properly.
1950 MG-TD
