Author Topic: Steering Wheel  (Read 599 times)
Doug Wilber
  • USA, MA, Great Barrington
Steering Wheel
« on: August 13, 2025, 18:36:24 »
Anyone know if the steering wheel hub on a W107 is the same as W113 280SL year 1969?
Doug
1969 280 SL
Dark Green, Black int.
Owned 37 years
lreppond
  • USA, CA, San Leandro
Re: Steering Wheel
« Reply #1 on: August 13, 2025, 18:57:43 »
The R107 steering wheel fits perfectly on a w113 (280).  I’m not sure the hub is the same (R107 might be molded plastic rather than painted metal) but the connection points are the same.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
Doug Wilber
Re: Steering Wheel
« Reply #2 on: August 13, 2025, 19:12:47 »
Thank you. Looking for Hub to connect Nardi Wheel.
Doug
1969 280 SL
Owned 37 years
WRe
Re: Steering Wheel
« Reply #3 on: August 13, 2025, 21:13:49 »
the R107 came from the factory with two different steering column/hub options:
Diameter - 15.20 mm with 47 teeth/splines (same for W113) and
Diameter - 21.35 mm with 66 teeth/splines.
...WRe
Doug Wilber
Re: Steering Wheel
« Reply #4 on: August 13, 2025, 21:21:51 »
Thank you. Very helpful
Doug
1969 280 SL
Owned 37 years
Doug Wilber
Re: Steering Wheel
« Reply #5 on: August 13, 2025, 21:45:47 »
So the horn contact would be the same as it is on the W113
Doug
1969 280 SL
Owned 37 years
