Author Topic: Original gas cap maintenance  (Read 1070 times)
« on: July 26, 2025, 11:39:12 »
After seeing Len have a gas cap failure (https://www.sl113.org/forums/index.php?topic=39613.0), and knowing the cost of replacements, I was wondering if there is any "maintenance" that can be performed to extend the life of original gas caps.
Can we agree on what type of lubricant, if any, should be put in the key hole?
Should anything else be lubricated?
Can we agree on how often to replace the gasket with original type material?
Is that little spring replaceable?
Your thoughts?
« Last Edit: July 26, 2025, 11:43:24 by rwmastel »
merrill
Re: Original gas cap maintenance
« Reply #1 on: July 27, 2025, 14:41:48 »
the recent posts reminded me to lubricate the gas cap on my 66.
1. Sprayed "super lube" synthetic on the inner workings
2.  applied a thin layer of "syl glide" to the rubber gasket
key turns super smooth and the cap rotates very easily.
« Last Edit: August 01, 2025, 16:31:31 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #2 on: July 31, 2025, 22:54:48 »
... on the inner workings applied a thin layer ...
Did you take it apart some how?
merrill
« Reply #3 on: August 01, 2025, 16:32:50 »
hi,
updated my post.
the super lube is a spray, using the supplied tube i inserted the tube in any gaps and sprayed.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
