Author Topic: HELP! Can’t remove gas cap.  (Read 4812 times)
lreppond
  • USA, CA, San Leandro
« on: July 16, 2025, 20:43:57 »
I went to the gas station this morning but couldn’t remove my gas cap.  When in the locked position, it spins freely as it should.  When in the unlocked position the outer portion of the cap won’t lock up allowing me to twist it to the left to remove.  It holds in place until I apply even the slighest torque at which point it spins.  Anyone else experience this?  How did you end up removing it.  With the cost of these caps I hate to destroy it but I’m at whits end.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: HELP! Can’t remove gas cap.
« Reply #1 on: July 16, 2025, 23:51:11 »
I put a new cork seal on my cap a few years ago and once in, I could not get it to turn to come off. The cork was/is a slight bit thicker than the original seal. What I did was to use white grease on the seal, so now it comes off easy. When I am turning it at take off, the key is still in and it is in the unlock position, which it keeps the cap from spinning freely. When you turn key to unlock, and add some torque, does it still spin freely?  If so the lock tumbler is the problem.
Robert Hyatt
Williamsburg, VA.
lreppond
« Reply #2 on: July 17, 2025, 00:54:47 »
I’ve tried it with the key left in and taken out. The cap just keeps slipping.  It’s not a free spin as when in the open position but when left torque is applied it slips rather than spinning.  I’ve tried pulling when twisting and pushing while twisting to no avail.  Whatever mechanism that holds the outer cap stationary when unlocked seems to have failed.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
Hans2012
  • USA, TX, Houston
« Reply #3 on: July 17, 2025, 02:18:24 »
Len
I had the same issue.  My problem was that I was not able to get enough leverage on the cap to get it to turn because the seal was too tight and the positioning of the cap makes it difficult to get purchase.  What ended up working for me was to put on a close fitting rubber glove (what a mechanic or a surgeon might use) - that helped make a non-slip connection with the gas cap.  Keep a glove or two in the trunk - has worked every time.
Good luck.
Cheers
John
1971 280 SL - 268 Dark Green - Cognac Leather
lreppond
« Reply #4 on: July 17, 2025, 05:43:28 »
Len
Good luck.
Cheers
John
I have no issues gripping it.  The problem is that when unlocked, ratchets should engage the outer chrome portion of the cap to the inner portion which then allows you to twist the cap off. The ratchets are either worn down or the spring that pushes them out isn't functioning properly.  Much as I hate to, I’m afraid I’ll have to destroy my cap to be able to remove it.  If you’ve looked at the price of these lately you’ll understand why I don’t want to do that. I may have no choice.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #5 on: July 17, 2025, 06:05:40 »
For what it is worth, I am not at the car now, but in this kind of situation any, even silly, thought may give a clue…
When you study how the cap works in our Technical Manual, you may conclude that the little tab that locks the chrome part is not getting fully in.
Perhaps it is possible, having taped surround of the cap with masking tape not to scratch the paint:
- turn the chrome and feel when it slightly engages - the may be the place where the tab is aligned with where it needs to get in to lock the chrome
- try to tap the cap - maybe it will go in
- bend wire to make a hook with a short bent part and try to find the hole under gasket to push in the tab
When you look in the Manual you will see what I am after.
Hope someone will chime in who did unlock the cap in this situation…
« Last Edit: July 17, 2025, 07:16:48 by Pawel66 »
« Reply #6 on: July 17, 2025, 06:16:10 »
Alternatively: if you are able to locate one of the two holes under the gasket, I would try to insert a, say, 2mm punch (or small screwdriver or a pick or L shaped pick with lower part of the L cut to 2mm) and tap it with a small hammer to turn the cap left to undo it.
I think locking is only between chromed crown and the core of the cap so the point is to skip the chrome crown and turn the core. These holes are in the core.
« Last Edit: July 17, 2025, 07:17:16 by Pawel66 »
LakisAkylas
  • USA, MA, Newton
« Reply #7 on: July 17, 2025, 14:04:55 »
Hello Len,
I have experienced this same (very frustrating!) issue with my locking gas cap. (Mine is the late 280SL version that uses the same key as the ignition, doors, trunk and glove box.)  I was able to resolve it by turning the key in the locked and unlocked position a few times, while also rotating the cap until the cap finally caught on. I think the problem is somehow related to the lock cylinder moving slightly in and out as you turn the key.  When it first happened I panicked and thought I may be forced to ruin the cap (which is NLA and extremely expensive!), but now know how to handle it. Feel free to pm me if you want to discuss details.
Lakis
lreppond
« Reply #8 on: July 17, 2025, 14:59:40 »
Pawel & Lakis,
Both of you understand what the problem is.  I’m about to go to the garage and try your suggestions.  Working on this isn’t easy because there is very little space and the fear of collateral damage!
Pawel: the idea of tapping the outer cap to attempt to engage the locking teeth may work.  I’ve also thought of getting a thin metal shim and trying to cram between the inner and outer caps.  Last night I tried placing superglue between them.  All failed because of lack of access space.
Lakis: if your solution works in my situation it’ll be wonderful.  I’m going to try it first since it’s the easiest and least invasive/damaging.
Will report back later.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #9 on: July 17, 2025, 17:18:13 »
I would make sure I understand how it all works first (I am not sure if I do correctly).
If it does not go by wiggling the key, I would remove the lamp, tape the fuel neck around and try to locate the hole under gasket. To turn you have to overcome friction of the gasket and spring load.
BobH
« Reply #10 on: July 17, 2025, 17:39:36 »
If you have no luck with turning the cap and the key at the same time, as Lakis suggests, then it looks to me that one of the small holes Pawel mentions actually releases the chrome spinning top from the locking part of the cap, have a look in the tech manual.  The only problem, apart from the difficult access when it's on the car, is that the gasket covers the holes, so you'll need to search with a mirror behind the cap to find the correct hole
https://www.sl113.org/wiki/Fuel/LockingGasCap
The top seems to come away quite easily, the member on here found it came apart when dropped, it exposes what i guess is the spring loaded locking bolt, which i assume is what engages when unlocked
https://www.sl113.org/forums/index.php?topic=34169.msg250137#msg250137
Good luck!
« Last Edit: July 17, 2025, 18:26:50 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lreppond
« Reply #11 on: July 17, 2025, 19:11:03 »
I tried both Pawel and Lakis’ suggestions to no avail.  My level of patience only lasts for 15 minutes and then I have to walk away.
Bob: funny thing you should mention the outer cap falling off easily. My mechanic said that if you put enough force on it’ll pop off. Of course my arthritic shoulders and fingers have left my strength somewhat compromised. But before I hire a flat bed to drive it to the shop, I’ll give it a try
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
BobH
« Reply #12 on: July 17, 2025, 19:49:58 »
I thought i'd go and have a look at how easy it would be to access the hole that releases the spinning top from the body of the cap, and what do you know, i don't have these holes on my cap, either the earlier caps didn't have them, or else i can't guess why mine is different from the one in the tech manual
However, i think with a mirror and some magic, and someone with small hands and some dexterity, a 90 degree spiked tool, similar to a dentist pick, could move the gasket aside, and could then penetrate the hole and release the spinning top
Let's hope your cap has the hole
UK delivered RHD
Blue soft top
Blue leather
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #13 on: July 17, 2025, 20:03:47 »
Just a thought...
If it's possible to get to the gasket enough to move it aside, perhaps it could be cut, then pulled out (with needle-nosed pliers or a hemostat or ?).  Once the gasket was pulled out, I suspect it would be easy to turn the inside part of the cap.
      -David
-David Pease
BOTIGER1970
  • USA, NC, Mooresville
« Reply #14 on: July 17, 2025, 20:09:37 »
For what is worth, before I would do anything else, I would spray penetrating oil everywhere possible, including the key hole.  The mechanism might just be hanging up.  Also, be patient and wait overnight before trying the gas cap again.  Sorry if this is a repeat or you have already thought of this.
Mark
lreppond
« Reply #15 on: July 17, 2025, 21:32:31 »
Thanks to all for your suggestions.  Still no luck but I know I’ll eventually figure this out.
Bob: using a dental mirror I see no holes under the gasket.  I dont think the two sided key ones had these holes.
David: havent tried removing the gasket yet.  It’ll at least give me  a little more wiggle room.
Mark: I sprayed it with white lithium grease (both key & mechanism).  Waiting to see if it helps.
Len
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
49er
  • USA, CA, El Dorado Hills
« Reply #16 on: July 17, 2025, 22:09:22 »
Len, I really feel for you on the problem you are having. I wish you good luck in resolving it.
John
1969 280SL 003820
4 speed manual, PS. 77K+miles
7K+ miles since awoken from her 20+ yr "nap" in 2010
« Reply #17 on: July 18, 2025, 00:52:07 »
Irrepond,
Wow that is a really stuck position.
Follow Pawel and tap on the cap with the key in lock position and unlock position a few times.  Most likely the tabs inside that lock the chrome portion from the inner portion are corroded and not moving enough.
Tapping will help move them.
Might also try spraying brake/carburator cleaner into the keyhole with the plastic tube to get the gunk inside loosened.
Then tapping again a bit harder with a plastic head mallet, not to damage the chrome. Iron or Steel hammers will damage the chrome, copper won't(bit harder to find), like the older British cars with the knockoff wheels.
Keep us posted on your progress.
Walter Klatt
1967 220SL diesel
1969 280SE
2003 Beetle TDI
2005 Honda Element
yves
  • France, Poitou-Charentes
« Reply #18 on: July 18, 2025, 06:12:58 »
If it can help...?
« Reply #19 on: July 18, 2025, 19:28:57 »
I have my original cap in the drawer, I will get there Monday…. Late, you will have it done by then, I am sure.
« Reply #20 on: July 18, 2025, 19:37:27 »
If it can help...?
Maybe I am wrong, but:
1. The key turns the tumbler
2. Tumbler turns and offers space for the locking tab you see in the chrome part to move in and engage the with the core/inner part
3. This engagement requires alignment not only in horizontal, but also in vertical dimension.
4. When you find by feel where is the engagement moment in the horizontal dimension, the new part may be fiddling the key and tumbler up and down to match the horizontal dimension as well
So not only left and right but also up and down may be important…
I think…
« Reply #21 on: July 18, 2025, 20:15:16 »
If it can help...?
Fantastic pic!  I've not seen the inside before.  And, on the part on the left, you can see the two holes people have referenced.  On the perimeter, near top and bottom.
lreppond
« Reply #22 on: July 18, 2025, 22:33:07 »
I have essentially tried everything I can think of and still can’t remove the cap.  Knowing how the locking mechanism works has been helpful in trying different strategies but nothing has worked.    At this point I’m really afraid of damaging the filler neck and doing more damage than just the cap.
Since it lacks sufficient gas to get me to my normal shop, I’ll get a flatbed to transport it there on Monday.
No one needs this level of frustration in their life!
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #23 on: July 18, 2025, 22:41:18 »
Looking at piece A in the picture the sliding tab may have broken where it is thinner.  The broken piece would not slide in to engage one of the tabs in B.  If you can get a paper clip into the channel and force the piece towards the center of the cap it may give you one shot at engaging a tab on piece B.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
lreppond
« Reply #24 on: July 18, 2025, 22:55:32 »
Thank you for the suggestion.  The space between the outer and inner cap is too small to allow the clip to fit.  This was one of the first thing I tried.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
