Author Topic: Crunching noise coming from A pillar area  (Read 862 times)
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« on: July 15, 2025, 21:23:26 »
My car has started to make crunching noises coming from (I think) where the front of passenger door fits under the A Pillar (edge of windshield).  It sounds like friction rather than a mechanical rotational noise.
Has anyone experienced that?
I was in direct sunlight for 5+ hours on Sunday mostly sitting at traffic lights or crawling on the freeway while I cooked in my black leather interior.   I don't know if the door expanded in the heat.
Is my door misaligned.   I don't remember doing anything more stupid than normal in my car.
Is there a lubricant that may help?
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
Re: Crunching noise coming from A pillar area
« Reply #1 on: July 16, 2025, 00:36:40 »
There are lubrication points on the hinges (search door hinge lube).  I can't imagine heat expanding the door and closing the gap, but I'm not a metallurgist.
lreppond
  • USA, CA, San Leandro
« Reply #2 on: July 16, 2025, 20:53:12 »
I think it may your door check assembly or the door check cam.  There’s a Teflon roller on the check that wears out and will make a odd noise as you open the door.  Usually it makes the noise twice since the cam stops the door in two positions.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
