Author Topic: Breather Tube Cover Installation  (Read 1117 times)
LindesayOne
  • Canada, Alberta, Edmonton
    • LindesayOne
« on: July 02, 2025, 18:14:01 »
Greetings folks,
Having acquired a new rubber cover for the breather hose on my 69 280SL, I'm struggling to slip it over the two pipes. In the absence of silcone I liberally applied all components with vasalene but to no avail. I'm afraid of breaking the plastic tube.
Any tips would be much appreciated.
John
John
1957 190SL 8500074 (RIP?)
1968 280SL 11304410006390 (RIP?)
1969 280SL 113044120011428 - Light Beige/Cognac
Jack the Knife
  • USA, FL, Vero Beach
Re: Breather Tube Cover Installation
« Reply #1 on: July 02, 2025, 18:31:12 »
Can you post photos of the components?
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
LindesayOne
    • LindesayOne
« Reply #2 on: July 02, 2025, 21:05:14 »
Photo: Attempt in progress
John
Jack the Knife
« Reply #3 on: July 02, 2025, 21:37:02 »
Maybe try to warm it up. I'd also probably do the larger tube first, if it was me. But I'm not speaking from experience since my breather tube is different.
LindesayOne
    • LindesayOne
« Reply #4 on: July 02, 2025, 21:47:05 »
Worth a try. Thanks
John
John
707dieseldean
  • USA, CA, Santa Rosa
« Reply #5 on: July 02, 2025, 23:15:19 »
Soak the rubber in very hot water, then apply some dish soap to the inside of the rubber. Should help it slide. Use a hair drier if needed to re apply heat.
69 280SL / Manual 4 speed
 904 - Lower Midnight Blue
 158 - Upper White/Grey
 145- Vellum Interior
LindesayOne
    • LindesayOne
« Reply #6 on: July 03, 2025, 01:05:45 »
The hot water did it.
Thanks Guys!
John
John
