Author Topic: 230 sl and 280sl  (Read 986 times)
Seamus52
  • USA, MI, Cheboygan
230 sl and 280sl
« on: July 01, 2025, 00:51:20 »
I have a chance to  buy 4 speed gear box from a early 280 sl 1967 is this the same gear box as my 1965 230 sl I understand that there is a difference with the later 280 sl trying to make sure
Jack the Knife
  • USA, FL, Vero Beach
Re: 230 sl and 280sl
« Reply #1 on: July 01, 2025, 01:37:14 »
There's different gearing, with the earliest 230SL transmissions being a little bit lower. I can't recall any other differences, though I'm sure others will know.
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
Seamus52
« Reply #2 on: July 01, 2025, 19:04:55 »
Thank you Jack do you know any sources that could verify that the gear boxes are  the same one source told 280 was different but tthis is a early 280 1967
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #3 on: July 01, 2025, 21:04:20 »
Hi, Seamus,
I know nothing about transmissions, but I'm sure I've read somewhere on the forum that the flywheels for the earlier and later transmissions are not interchangeable.  That would make me suspect that there could be a difference somewhere.  Have you checked part numbers for the two models to see if they're the same (or if the 230SL part number is replaced by the 280SL part number)?
Just my thoughts,
        -David
-David Pease
