Author Topic: Brake reservoir port  (Read 1156 times)
CJHenderson
  • USA, AR, Benton
« on: June 15, 2025, 22:40:39 »
Which reservoir port goes to the front, and which goes to the rear brakes?
1950 MG-TD
WRe
Re: Brake reservoir port
« Reply #1 on: June 16, 2025, 06:15:57 »
I'm not sure if I've understood your question correctly, but maybe the pictures in the links will help:
- https://www.sl113.org/forums/index.php?topic=33686.msg246545#msg246545
- https://www.sl113.org/forums/index.php?topic=25854.msg185145#msg185145
...WRe
« Reply #2 on: June 16, 2025, 13:10:43 »
You can probably determine that by following the lines coming out of the ports?
WRe
« Reply #3 on: June 16, 2025, 17:35:48 »
If the orientation of the brake lines was meant, it is not really possible to mix them up, as two lines are connected at the end (from the point of view of the brake booster) of the brake master cylinder for the front brakes and only one at the front of the brake master cylinder for the rear brakes.
...WRe
