Author Topic: Engine bay wire routing PICs needed please.  (Read 1985 times)
hemibeep
  • USA, FL, Oldsmar
« on: May 18, 2025, 17:10:03 »
Hello all.
I am restoring my car and took hundreds of photos, however I do not see the routing for the wire loom around the battery tray and the routing for the wires going to headlights.
I am in assemble stage- I did not locate any previous posts. thank you.
Any photos of these areas would be helpful.
1970
Re: Engine bay wire routing PICs needed please.
« Reply #1 on: June 04, 2025, 22:20:48 »
Welcome to the Group!  It will help if you add a signature line that includes the year and model of your Pagoda.  I'm sure wiring changed over the years.
Leester
  • USA, VA, Lorton
« Reply #2 on: June 04, 2025, 22:45:19 »
Rodd is, as usual, correct. There are wiring differences between models and even within the same model. I went through what you are going through over the last few years and from experience I can tell you that a full membership is a bargain. I can't tell you how many times access to the full member section helped me, especially with electrical issues.
Lee Backus
1963 220SE Cabriolet
« Reply #3 on: June 05, 2025, 00:28:04 »
He is a full member.  I assume you're talking about wiring diagrams in the Tech Manual?
https://www.sl113.org/wiki/Electrical/WiringDiagram
WRe
« Reply #4 on: June 05, 2025, 06:32:34 »
Maybe these pictures will help.
And here: https://www.sl113.org/forums/index.php?topic=33975.msg248493#msg248493
...WRe
« Last Edit: June 05, 2025, 06:41:46 by WRe »
hemibeep
  • USA, FL, Oldsmar
« Reply #5 on: June 10, 2025, 00:47:12 »
Thank you for the information.
I cannot locate the photos of wire routing from disassembly.
1970 model.
1970
