Author Topic: Tab on left inner fender  (Read 6108 times)
BOTIGER1970
  • USA, NC, Mooresville
« on: October 02, 2021, 22:56:07 »
Does anyone have the tab that is on the left inner fender for where I believe the battery tray connects.  The tab is welded to the inner fender.  If anyone can send me pictures of both sides of the tab and the dimensions, I probably can make one. I appreciate any help.
Mark
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Tab on left inner fender
« Reply #1 on: October 02, 2021, 23:54:21 »
Does this help?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
dirkbalter
  • USA, CA, Corona
« Reply #2 on: October 03, 2021, 02:19:23 »
One more for clarity.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BOTIGER1970
« Reply #3 on: October 03, 2021, 18:51:13 »
Thanks to both for the pictures.  I'm probably making this harder than it has to be, but a couple questions.  Is there a welded nut underneath.  Would either of you be so kind as to give me the measurements of this piece.  Thanks in advance for your help.
Mark
dirkbalter
  • USA, CA, Corona
« Reply #4 on: October 03, 2021, 19:24:26 »
M6 welded hex nut from underneath, 10mm in from front edge. Bracket is 80mm long and 35mm deep. Hope that helps
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BOTIGER1970
« Reply #5 on: October 03, 2021, 19:34:13 »
Thank you that helps.  Much appreciated.
Sincerely,
Mark
