Author Topic: 3 point belts  (Read 4556 times)
opopotts
  • Canada, ON, Douglas Dees
3 point belts
« on: April 16, 2025, 20:58:05 »
My 1961 1961 220  SE coupe has old lap belts which I want to change to 3 point belts Is there an anchor point on the early coupes for a metal bracket under the leather to attach an anchor?
Opopotts
Re: 3 point belts
« Reply #1 on: April 17, 2025, 14:54:23 »
Are you talking about the threaded sleeve that is on the upper door panel at the rear quarter window? If so, it would be below the panel cap. That cap can be easily removed. It is held on by one screw in the chrome strip at the rear and (2) push clips. Will also have to remove the upper chrome plate on the door jam facing the rear. I can't remember the the rear seat back has to be removed also.
I can snap a picture later today of what it looks like.
opopotts
Re: 3 point belts
« Reply #2 on: April 17, 2025, 15:39:11 »
Yes Please . So that fastener was hidden on the early Models?
Doug
Re: 3 point belts
« Reply #3 on: April 17, 2025, 22:34:30 »
Here is the anchor. It is simply welded on the steel rail. Then a hole is put in the cap frame and leather. It could be under the cap, not sure when that was done and maybe if an option.
You can see the two slots where the clips fit into that are mounted on the cap. The clips are part number #002 988 45 78.   https://www.authenticclassics.com/DOOR-TRIM-RAIL-MOUNTING-CLIP-FITS-100-107-108ch-p/auth-009259.htm
thomasw
  • Sweden, Blekinge, Halmstad
Re: 3 point belts
« Reply #4 on: June 09, 2025, 17:57:36 »
Wallace, i also have a 220 SE coupe bit this was delivered in june 1961, i read somewhere that my car does not have this welded anchor point. Is there some reinforcement under the tube?
And how did you do with the roller end? Is it hidden under the side panel?
Thomas
W128 4-door & W111 2-door
Re: 3 point belts
« Reply #5 on: June 10, 2025, 03:20:17 »
The tube is welded on the steel rail. No reinforcement that I see. The leather covered cap that fits on top of the side panel is about 1/8" or so above the top of the tube when installed so the tube is not visible. There is a hole (opening) in the cap that aligns with the tube. Hopefully that helps.
thomasw
Re: 3 point belts
« Reply #6 on: June 10, 2025, 05:22:26 »
Thanks!
Thomas
Re: 3 point belts
« Reply #7 on: June 10, 2025, 19:55:36 »
I'll take a picture tonight. The hole in the cap is about 7" to the rear of the cap's leading edge..
Re: 3 point belts
« Reply #8 on: June 11, 2025, 02:41:55 »
Gives you an idea of the hole for the 3 point seat belt mount in the rear. Mine had that from the factory and of course in Kangol.
opopotts
Re: 3 point belts
« Reply #9 on: June 11, 2025, 21:43:45 »
I am going to take my panel off next week to see if I have the stud. It currently has lap belts
opopotts
Re: 3 point belts
« Reply #10 on: June 19, 2025, 22:08:49 »
I took the cover off and there is no stud for 3 point belt fastening so I think that I will just put in new lap belts
