Author Topic: I have replaced power Steering Box with a new one now what fluid to fill with?  (Read 2646 times)
Pinder
  • USA, NJ, Edison
Hi everyone. I finally got round to fixing a leak on my power steering box. I tried using the quick fix to replace the seals at the bottom of the box but it did not work. I ordered a new power steering box (rebuild) and have fitted it into the car and its ready for fluid.  What is the correct fluid to use?
Regards
 Pinder
« Last Edit: April 22, 2024, 15:45:45 by Pinder »
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
WRe
ATF fluid, MB 236.3.
...WRe
Hi everyone. I finally got round to fixing a leak on my power steering box. I tried using the quick fix to replace the seals at the bottom of the pump but it did not work. I ordered a new pump (rebuild) and have fitted it into the car are its ready for fluid.  What is the correct fluid to use?
Did you change your POWER STEERING PUMP, the STEERING BOX, or both? Both of mine are leaky and it's next up on my list...along with the hoses.
TJMart
  • USA, NC, Matthews
Pinder,
I used Mercedes Power Steering Fluid compliant with MB 236.3.
https://operatingfluids.mercedes-benz.com/sheet/236.3
Tony
Tony
1970 280SL, 4 Speed
You are a Full Member. You have access to and you can use this resource: https://www.sl113.org/wiki/Restricted/ServiceManual
You have all the fluids and all the capacities there.
Part number for 1 liter: A000989880310. You need 1.4 liters.
Pinder
  • USA, NJ, Edison
thanks everyone.
I replaced only the power steering box. not the pump.
It was relatively straight forward to change although I needed a little help holding the pump from top and me installing it from the bottom.
I ordered the pump from Autohaus AZ . It came within a week.  It came well packaged. I have to return my old one for a core charge.
