Author Topic: Becker Europa MU - Stereo - 7 Pin (DIN) cable question.  (Read 4646 times)
PNWSL
« on: February 15, 2024, 19:16:27 »
Hello everyone.
I am trying to utilize the 7 pin (cassette) input in my Becker Europa MU Stereo but when I plug in the cable purchased i get no sound from the music source.  Once I unplug I get FM/AM radio with sound without issue.
Here is the 7 PIN to 3.5mm cable I purchased.
https://www.amazon.com/gp/product/B08G1BXT4H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
My stereo has the separate AMP located behind the dash. The 7 pin input is at the back of the stereo itself.
Did I buy the wrong 7 pin to 3.5mm cable? Or am i functionally not setting up the radio correctly?
Thanks for your input
Re: Becker Europa MU - Stereo - 7 Pin (DIN) cable question.
« Reply #1 on: February 15, 2024, 21:14:40 »
I see this is your first post.  Welcome to the Group!  If you feel so inclined, you can introduce yourself here: https://www.sl113.org/forums/index.php?topic=529.0
It can also help if you put the model/year of your car in your signature or profile so people know what you have when trying to give advice/assistance.
PNWSL
« Reply #2 on: February 15, 2024, 21:34:37 »
Thank You, I currently don't own a W113 but an Early R107. Came across this forum as there are some shared parts between the two models.
Signature Updated.
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #3 on: February 15, 2024, 22:33:06 »
You might try asking Becker. They are located in NJ.
 https://www.beckerautosound.com/
They helped me when I had a question about my radio.
Lori
1968 280SL (US)
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #4 on: February 16, 2024, 01:55:39 »
I very much doubt that the generic Chinese adapter you bought, which appears to be designed for home amplifiers, would ever work with your Becker Europa.
Perhaps this would do what you want; it claims to work with the Europa, and it's from one of our trusted suppliers:
   https://www.authenticclassics.com/DIN-Plug-Bluetooth-Adapter-for-Stereo-Becker-Radio-p/auth-007527.htm
I use a similar adpater designed for my much older Becker Mexico (5-pin DIN, mono) radio, where I have a special button ("Q") to select tape (i.e., DIN connector) input.
         -David
-David Pease
PNWSL
« Reply #5 on: February 16, 2024, 16:09:51 »
Thanks, yes used Becker in NJ previously for a rebuild, Quality Outfit
PNWSL
« Reply #6 on: February 16, 2024, 16:13:04 »
         -David
Yep, You are probably right, I figured 7 pin DIN  to 3.55,, would be a sufficient cable for source transfer,  evidently not.
GM
  • USA, CO, Boulder
« Reply #7 on: February 16, 2024, 18:49:13 »
Recommend reaching out to Massoud at Creative Car Audio Shop
https://creativecaraudioshop.com/
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
PNWSL
« Reply #8 on: February 17, 2024, 05:40:57 »
Thanks, I am likely going with this outfit.
Appreciate the recommendation
