Author Topic: Idle speed /constant speed control  (Read 2742 times)
Esmo
  • United Kingdom, Wales, Conwy
  • SL 230 1967
« on: February 22, 2023, 16:05:05 »
Hi My 1967 SL230 automatic,has been set up by a specialist who tells me that the idle speed control 000 072 05 00 has failed and any used ones are not worth it as it’s a common problem . Having checked MB main dealer , SLShop ,SLS all confirm not available . Niemoller in Germany do offer a rebuild 8weeks and over a £1000 including tax exc shipping . My question is does anyone know of a rebuild service in the U.K. ?
Re: Idle speed /constant speed control
« Reply #1 on: February 22, 2023, 16:27:05 »
I can probably make yours work again.
« Last Edit: February 23, 2023, 20:07:06 by stickandrudderman »
« Reply #2 on: February 22, 2023, 16:31:57 »
What you call "idle speed control" is also called "constant speed solenoid" or CSS.  I see you are a full member, so here in the Tech Manual you will find a part number for an interior seal.  See if it is still available.  https://www.sl113.org/wiki/Restricted/Linkage-tour#ConstantSpeedSolenoid
How do these work internally?  They get the signal from the auto transmission and/or air conditioner, then what pushes the rod out?  Is there an electromagnet and spring inside?  I would think a bimetallic spring heated by electricity would not have the necessary force.
« Last Edit: February 22, 2023, 16:38:37 by rwmastel »
BobH
« Reply #3 on: February 22, 2023, 17:22:15 »
Might just be worth testing it yourself, easy to confirm if it's working electrically or not, good advice on this post
https://www.sl113.org/forums/index.php?topic=451.0#:~:text=The%20solenoid%20works%20electrically%20through%20contacts%20of%20the,it%20might%20just%20be%20the%20idle%20switch%20adjustment.
it's a solenoid, so, an electromagnet, attracts or repels the pin/rod
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #4 on: February 22, 2023, 18:56:42 »
So, I looked up solenoid and found this basic, easy to understand video:  https://www.tlxtech.com/articles/solenoid-101-what-is-a-solenoid
Why would that fail?  All I can think of is moisture gets in there and corrosion happens.  Any other reasons they fail?  Such a simple device.  Oh, and the moisture issue goes back to what I found in the Tech Manual about a seal.
